Post by thxcuz on May 2, 2017 9:22:11 GMT -5
Not having a good morning. Battery is fully charged. I mash start button, solonoid clicks the bendix moves slightly but doesnt turn. I hope it's not a fried starter. Also some clown WELDED a bracket for a side stand right over where the center stand would go. Sheesh!
Post by thxcuz on May 2, 2017 12:23:28 GMT -5
Seems I have a bad starter button.
Post by thxcuz on May 2, 2017 21:14:45 GMT -5
Great Scott, Marty, the bloody thing started!
start button does nothing now, the relay just buzzes, and the starting motor...well, we wont talk about what I may have done to the starting motor. The first few teeth of the kick start gear are worn but I greased up the gears and fiddled with it anyway and on the 3rd kick it started! I didn't ride it due to the bad rear brake cable but I call that a victory! The wheel doesn't spin when I give it gas but I recon that's just the carb needing adjusting. So scooterwise, today was an emotional rollercoaster. I was excited about new parts, dissaointed about the centerstand nonsense, the bad starter button and the terrible crime I did against the starter motor. then excited again about it kicking over and running.
I'm spent
Post by 2stroked on May 2, 2017 23:28:07 GMT -5
I'm happy for ya, and I feel forya.
Post by thxcuz on May 3, 2017 7:04:00 GMT -5
All is not sunny in spreeland. I tried to kick it over again and it wouldn't start. I have a theory why but my bigger problem is that I stripped the either kick lever or the shaft. It's weird. The lever is loose but also stuck on the shaft. So I have a scooter that does run. I just have no way to get it to run.
Post by 2stroked on May 3, 2017 10:24:21 GMT -5
Grrrrrrrr Good luck
Post by thxcuz on May 9, 2017 22:55:11 GMT -5
kick start is shot...the only alternative I have is to drill through the shaft and the lever and bolt it that way. not impossible, just not what I was expecting. Speaking of not what I was expecting, I think my mounting hole on my carb is stripped. UGH I had it start last week. a while later I tried it again and it started then died. I'll work on getting the electric start going next week. If I have bigger problems like a busted rod or something I am going to part it out. I've had better luck with Chinese scoots.
Post by benji on May 9, 2017 23:06:03 GMT -5
The threads strip pretty easy... just get a slightly longer bolt and use a nut. That's what was done to my stock aero carb.
Post by thxcuz on May 12, 2017 14:33:15 GMT -5
The threads strip pretty easy... just get a slightly longer bolt and use a nut. That's what was done to my stock aero carb. The not doesn't fit behind the hole... I guess I can find thinner nuts or grind them
Post by benji on May 12, 2017 15:35:49 GMT -5
You may have to do some clearancing. I had to do this same thing on my stock aero carb. Seals way better when your done tho!
Post by jbjhillbilly on May 14, 2017 19:24:03 GMT -5
OP - let me know what you're looking for. I just finished stripping a Spree apart. Haven't gotten into the case yet, but the kicker is good, and I can pull the shaft if you want as well. I'm sure we can work out something equitable (I'm rehabbing an 86 and and 87 Elite 150).
Post by eclark5483 on May 14, 2017 22:37:27 GMT -5
Just bought a red 87' Iowa Edition a couple hours ago. Gonna be a sweet looking ride when I finish.
Post by thxcuz on May 14, 2017 23:51:03 GMT -5
Just bought a red 87' Iowa Edition a couple hours ago. Gonna be a sweet looking ride when I finish. Is that going to go 60mph like your yellow one?
Post by eclark5483 on May 15, 2017 0:24:04 GMT -5
Can't say. It's my first time working with the Variated AF05E. First time I've done an engine swap. I expect it will perform better then my yellow one simply because of the CVT.
Post by thxcuz on May 15, 2017 11:53:37 GMT -5
So today I resolved the carb problem. And put the new starter on. Next I replaced the start button. I pushed it a few times with no response from the starter relay and oh yeah, the wiring in the right hand controls started smoking.
I'm going to look around for a short somewhere.
I also did some repair work on the plastics so I did achieve a little today
