Post by ryan_ott on Jun 25, 2017 20:47:43 GMT -5
I knew they would be noisy, I guess my exhaust is too quiet. I had gears on my Keeway but that exhaust was much louder so I guess I never noticed them.
Post by tsimi on Jun 25, 2017 21:46:57 GMT -5
Time to put your self made pipe back on.
Post by birdman on Jun 25, 2017 23:04:44 GMT -5
I had straight cut gears on once for a short while, They were noisy but that didnt really bother me that much. The fact that they hindered my ability to do wheelies is what bothered me. I could imagine how that noise could be nerve wrecking though. It sounds great tho, cant wait until you start riding it and show some vids.
Post by ryan_ott on Jun 26, 2017 10:22:30 GMT -5
Time to put your self made pipe back on. That one may be too much pipe for this motor. I could always try it at a later date. Plus I'd have to redo the mount to use with the torsen arm.
Post by 190mech on Jun 26, 2017 11:57:30 GMT -5
They do use moly paste for building up engines,especially on cam and lifters as they are very highly loaded and need all the lube they can get during the initial start up..Moly Paste would work well also in a scoot tranny..
Post by ryan_ott on Jun 26, 2017 18:06:00 GMT -5
Thanks John. I'll give them a few miles to break in, or just try heavier weight oil. If not I'll try some moly. Edit: I mean the moly lube
Post by ryan_ott on Jun 26, 2017 18:16:56 GMT -5
Post by ryan_ott on Jun 26, 2017 18:21:48 GMT -5
Actually I think you can hear the gear noise better in this one. When ever I slow down I hear it in the vid. I'm over it though.
Post by spaz12 on Jun 26, 2017 23:48:26 GMT -5
That's such a cool angle to mount cameras.
Post by ryan_ott on Jun 27, 2017 5:10:14 GMT -5
I made the same route before I made some tuning adjustments and I scraped the camera on the ground on the low corner towards the end.
Post by ryan_ott on Jul 3, 2017 19:47:37 GMT -5
Ordered a carbon fiber rear fender.
Post by spaz12 on Jul 4, 2017 0:48:19 GMT -5
Clear coat it when you get it and it will look much better. You'll see what I mean.
Post by ryan_ott on Jul 4, 2017 7:48:36 GMT -5
Clear coat it when you get it and it will look much better. You'll see what I mean. Did you scuff it with a pad or just wipe it clean and spray it?
Post by ryan_ott on Jul 4, 2017 15:19:57 GMT -5
Setup the air box on the Zuma. Currently at 42/98 W7 with snorkel out and a few 1/2" holes in the box. It's running well and I'm happy so far.
Post by spaz12 on Jul 4, 2017 16:14:19 GMT -5
Clear coat it when you get it and it will look much better. You'll see what I mean. Did you scuff it with a pad or just wipe it clean and spray it? It's been years, but I believe that I took a scotch brite pad to it. Not that it sees a lot of use but it's held up very well. And of course I used a fuel and oil resistant paint, but you probably already know that.
