Post by 190mech on Aug 19, 2018 15:24:28 GMT -5
When you get her in,roll her over and lets take a look under her skirts!Pics please..
Post by ryan_ott on Aug 19, 2018 15:37:25 GMT -5
Of course! I’ll get the relevant info and pictures for all to see.
Post by ryan_ott on Aug 20, 2018 17:12:25 GMT -5
This should help get the groceries...
Post by ryan_ott on Aug 23, 2018 16:57:48 GMT -5
It’s here... More info later tonight.
Post by ryan_ott on Aug 23, 2018 18:07:13 GMT -5
Post by ryan_ott on Aug 25, 2018 17:27:44 GMT -5
I burnt up some premix and took the gopro along. Nothing special but if you’ve got some time to kill. This is the maiden voyage for the C16 I picked up. It’s exactly the same as before nothing was changed. I’m running around 9,800 with the max recall on the trailtech at 10,400. Maxing out at low 60’s @ 310 wfo, part throttle is around 260-280. I’m actually hesitant to pull this motor off... youtu.be/Kgx2HJ0fYKgyoutu.be/zE6PIdNW8jMyoutu.be/LSZ5jm9eUgo
Post by gsx600racer on Aug 25, 2018 19:28:27 GMT -5
I burnt up some premix and took the gopro along. Nothing special but if you’ve got some time to kill. This is the maiden voyage for the C16 I picked up. It’s exactly the same as before nothing was changed. I’m running around 9,800 with the max recall on the trailtech at 10,400. Maxing out at low 60’s @ 310 wfo, part throttle is around 260-280. I’m actually hesitant to pull this motor off... youtu.be/Kgx2HJ0fYKgyoutu.be/zE6PIdNW8jMyoutu.be/LSZ5jm9eUgoI wish my maiden voyage looked/sounded this good... I am too ashamed to post mine.
Post by 190mech on Aug 25, 2018 19:36:02 GMT -5
Darn! Thats a beefy small end on that conrod,,what is its rod length?
Post by ryan_ott on Aug 25, 2018 19:38:47 GMT -5
It’s a 85mm rod, 12 pin.
Post by ryan_ott on Aug 25, 2018 19:53:55 GMT -5
I wish my maiden voyage looked/sounded this good... I am too ashamed to post mine. [/quote] Here is the aftermath, don’t mind my dirty wheels
Post by ryan_ott on Sept 9, 2018 18:20:24 GMT -5
I finally got around to mounting the cylinder and getting proper timing numbers. Using a .12mm base I’m right at 190/130, squish using the Polini head is .68-.72mm the supplied Athena head was close to 1mm. I could only get that to work if I ran without a head gasket that id rather not do. That would of been 78-.82mm The Polini head is a o-ring head. Anyone want to cut an o ring groove in the Athena head for me? I forgot to order a reed block for it so I plan on getting a MVT large petal block then I can leak test it and wait for a rainy day to mount it up. For comparison he Athena head is 9.2cc and the Polini is 8.9cc. This piston extends into the combustion chamber so I’ll have to measure that.
Post by ryan_ott on Sept 16, 2018 17:17:17 GMT -5
Worked on some CVT maintenance today. All the wear parts look great. Cleaned and regreased the rear pulley because it was getting sticky. I used Toyota lithium soap grease. I’ll keep this updated as to how it holds up. I came across this stuff in a search for LS grease. I found a few posts that say this holds up to high heat in other applications so I figured I’d give it a try. So far so good.
I also swapped around some TD springs and ended up lightening the rollers. What a world of difference. I guess this pipe wanted some more rpm. I haven’t tested full speed but around the ‘hood it feels much better.
For my future reference:
2615 miles 10,200 4.7gr Polini 28kg spring
Post by PIG on Sept 16, 2018 17:25:06 GMT -5
Worked on some CVT maintenance today. All the wear parts look great. Cleaned and regreased the rear pulley because it was getting sticky. I used Toyota lithium soap grease. I’ll keep this updated as to how it holds up. I came across this stuff in a search for LS grease. I found a few posts that say this holds up to high heat in other applications so I figured I’d give it a try. So far so good. I also swapped around some TD springs and ended up lightening the rollers. What a world of difference. I guess this pipe wanted some more rpm. I haven’t tested full speed but around the ‘hood it feels much better. For my future reference: 2615 miles 10,200 4.7gr Polini +40% spring Is this the new Athena 80cc your taking about or still the 70cc motor?
Post by ryan_ott on Sept 16, 2018 17:43:52 GMT -5
The Polini motor, I’m waiting on a reed spacer then I’ll pressure check and throw the Athena in there.
Post by PIG on Sept 16, 2018 18:22:41 GMT -5
The Polini motor, I’m waiting on a reed spacer then I’ll pressure check and throw the Athena in there. Can’t wait to finally see what this kit is all about. People been talking about it forever. What pipe are you going to use?
