Post by Lucass2T on Jan 2, 2019 11:19:38 GMT -5
Wheres your powerband peak rpm wise with this setup? Mines around 11k with the yasuni c16 and metrakit aka athena evo.
Post by ryan_ott on Jan 2, 2019 11:46:16 GMT -5
I’m running it at 10,600 and it seems really happy there. I’ve tried up and down a few hundred rpm and my pants dyno didn’t notice much difference. Part throttle I can chugg along at 8500-9000 and it’s still got plenty of power there.
Post by islandscrub on Jan 2, 2019 12:29:31 GMT -5
Cool! How'd you get the speedo on the video?
Post by ryan_ott on Jan 2, 2019 13:35:19 GMT -5
Cool! How'd you get the speedo on the video? My GoPro Hero7 has a bunch of overlays you can add to the video after recording. Speedo, map, gforce, altitude, etc. It’s a cool feature. I think the camera has more to offer then I’ll ever use. Especially when I didn’t realize my YouTube was set to 1080 max upload resolution. I’ll have more dumb, boring videos soon.
Post by ryan_ott on Jan 6, 2019 12:42:15 GMT -5
I found that oil leak... And I think that’s the noise I was hearing.
Post by oldgeek on Jan 6, 2019 12:52:32 GMT -5
At least you found it before you destroyed it!
Post by ryan_ott on Jan 6, 2019 13:14:40 GMT -5
Me too because I’ve been racking up a bunch of miles the last few days. I guess it could of been worse.
Post by islandscrub on Jan 8, 2019 12:39:23 GMT -5
Did that just work itself out .. or did you just miss it? Weird.
Post by ryan_ott on Jan 8, 2019 13:27:25 GMT -5
Somehow it worked itself out I don’t think it’ll happen again because I used Loctite this time.
Post by benji on Jan 22, 2019 16:48:29 GMT -5
Makes me wanna check mine
Post by korayyzb on Jan 26, 2019 12:15:34 GMT -5
That thing is as actually faster than my Taiwan spec 2005 Bws 100.
Post by ryan_ott on Jan 26, 2019 17:46:21 GMT -5
That thing is as actually faster than my Taiwan spec 2005 Bws 100. For what it is it moves out pretty quick, has a decent top speed and has been really reliable for me. I’m really happy with what it has become.
Post by ryan_ott on Jan 26, 2019 18:18:43 GMT -5
Post by gsx600racer on Jan 27, 2019 0:30:51 GMT -5
I found that oil leak... And I think that’s the noise I was hearing. Good thing that the rear pulley is smooth on the back side.
Post by ryan_ott on Feb 10, 2019 21:42:56 GMT -5
I’m thinking of changing things up this is what happens when all other projects are done. I’ve been running a Polini cast of some sort I don’t even remember which one is on here I’ve got so many around. Choices: Airsal extreme 77cc -LC so I was thinking of a ruckus rad setup... I’ll have to pull the crank on the original motor to open up to 55mm. Once it’s opened up I’ll loose primary compression if I go back to a 47mm bore. Athena Evolution - same as the MKII, collecting dust on the shelf. Athena 80cc (77cc) - 43mm stroke - pulled this motor when I had an odd noise, still have the noise it’s in the exhaust. Actually I have a brand new spare cylinder so I have 2 of these. Besides the cylinder I don’t plan on changing anything still plan on running the 21mm PHBG and the C16 or my C21/30 if I go with the Airsal. Im thinking of running the Airsal 77, it’s just more work. What would you guys like to see?
