kglazer
Post by kglazer on May 27, 2011 21:28:53 GMT -5
hey guys i installed a tecknigas next r pipe on my s9 air cooled and put the rollers in that came with the kit. my problem now is that when i get to about 30mph i hit a flat spot and the engine just revs and it doesn't seem to be moving any faster. uphill although I'm getting like 40mph. on flats is where the problem is. some people said to up jet others said to get stiffer contra spring. I'm going to upgrade to 2000rpm clutch springs regardless of the problem to help my acceleration more. What do you guys think i should do to fix this problem?
kglazer
Post by kglazer on May 28, 2011 0:53:04 GMT -5
hey guys i did some searching and came across autotech355 has 3 torque springs and 3 clutch springs as a package all together on ebay and i would really like to buy this but i noticed in the picture that the packages are written in Chinese so does that mean they are knock off's and if so are they cheap ones that will be bad for my cvt. I'm not trying to knock on autotech355s products whatsoever I'm just looking to see if i should go with a name brand or not and if the ones from autotech355 will hold up for a long time? thanks
Post by 90GTVert on May 28, 2011 6:42:21 GMT -5
The ones from Autotech are fine. I've used them on multiple scoots and they hold up OK. Just be careful that you get the right stuff. I didn't know Autotech sold those kits for your scooter. Not saying he doesn't but just make sure before you order.
I'm not sure what to make of a scooter that goes faster uphill than on a flat. That's not something I've ever experienced. I don't think I'd try a stiffer contra for that. I'd actually think the opposite and maybe try heavier rollers or a softer contra. That's a wild guess though. Dunno if that would accomplish anything.
Post by Thebatman on May 28, 2011 8:13:38 GMT -5
:stumped: Now that is weird.. I thought that stuff only happened to me.. :lol: What weight are in it now? (idk what comes with pipe) What weights were in it?... If you order those springs, like 90 said, check them over for fitment. (make sure they not the cpi,zuma,mina,etc. springs) They wont fit. The gy6,kymco are correct size. The mina springs are narrower than the kymco/gy6. +1 on checking the rollers... But of course i am no master at this, we learn together ... How many miles on her? It's a good idea to keep the t.d greased, they do operate crappy when dried out..make sure the t.d is working correctly,no obstructions in the path.
kglazer
Post by kglazer on May 28, 2011 9:30:47 GMT -5
yeah i know only something like this would happen to me.i have no idea what size rolllers they r i forgot to way them :stumped: also what is the t.d
Post by 90GTVert on May 28, 2011 10:28:00 GMT -5
kglazer
Post by kglazer on May 28, 2011 10:57:51 GMT -5
thanks 90gtvert. i jsut called a shop by me and they said it sounds like a carb issue more then anything
kglazer
Post by kglazer on May 28, 2011 12:19:13 GMT -5
also i found out i have 6.5 grams in my variater. I'm gonna do a 1500 contra spring and 2000 rpm clutch spring and see if it solves my problem if not then ill look into the carb tunning. just to double check the super 9 50 air cooled engine is the same as a GY6 50cc,139QMB,QT50 engine right?
kglazer
Post by kglazer on May 29, 2011 0:47:13 GMT -5
any answers on the type of engine i have would be greatly appreciated i really want to order these parts :scoot2:
Post by 90GTVert on May 29, 2011 9:51:55 GMT -5
thebatman said the GY6/Kymco springs will work. The motor itself isn't the same as a GY6 50cc though, that's a four-stroke.
kglazer
Post by kglazer on May 29, 2011 10:01:31 GMT -5
ok thanks.
kglazer
Post by kglazer on May 31, 2011 20:38:45 GMT -5
hey guys i found a polini roller kit with 6.6gram, 7.6gram, 8.5gram, 9.1gram roller weights. is polini a good brand and do you think these will be the right sizes if im running 6.5 now and its stopping at 30 with the 1000 contra and 2000 clutch spring. or should i get even heavier ones? Also how can i tune my carburetor i know there are screws but idk what they are called or where they are and what they do a diagram and explanation would be great as i think the carb could be a issue of it topping out at 30mph
Post by drawkward on May 31, 2011 21:15:37 GMT -5
Polini is a good brand.
I have Autotech355's springs. They hold up decently - good for tuning mostly. They won't last forever, though.
kglazer
Post by kglazer on Jun 1, 2011 0:32:49 GMT -5
well how long is forever lol. I really wanna try and work on the carb tomorrow by playing with the screws does anyone know how to adjust them and what to look for and what to adjust if im having a flat spot. and i also think its sputtering when i give it gas from like 15mph and then finally kicks in and goes
Post by marshinman on Jun 1, 2011 5:38:13 GMT -5
