Post by kagetenshi on Oct 3, 2017 8:54:54 GMT -5
Any 12v battery should always be charged with a 12v source. The 6v chargers will only charge a battery to its intended 6v.
Post by jhill15 on Oct 3, 2017 9:17:16 GMT -5
Any 12v battery should always be charged with a 12v source. The 6v chargers will only charge a battery to its intended 6v. Gotcha, I will charge it on 12v when I get home.
Post by jhill15 on Oct 11, 2017 18:08:15 GMT -5
Any 12v battery should always be charged with a 12v source. The 6v chargers will only charge a battery to its intended 6v. I have been so busy with work and a bathroom Reno that I just got around to charging my battery today. Charged it on 12v and it fired up just fine! Thanks man.
Post by kagetenshi on Oct 11, 2017 18:37:45 GMT -5
Not a problem. Glad that resolved your issue.
Post by jhill15 on Nov 19, 2017 19:18:02 GMT -5
Took the scoot on probably it's final ride before winter. Just wondering what I should to winterize it, as it lives in a 8×10 metal shed with no heat. Should I take the battery out and store it indoors until spring? Any suggestions would be greatly appreciated!
Thanks everyone!
Post by kagetenshi on Nov 20, 2017 10:10:19 GMT -5
Take the battery inside, drain the gas from the tank and the carburetor. Check and/or change the engine oil depending on what condition it's in. That should be about it.
Post by jhill15 on Nov 20, 2017 13:34:51 GMT -5
Take the battery inside, drain the gas from the tank and the carburetor. Check and/or change the engine oil depending on what condition it's in. That should be about it. Thanks Kagetenshi! I only have about 180 miles on the oil. I'm not sure where the gas line is but I will figure it out if not I will check to see if Brent has a vid on it.
Post by kagetenshi on Nov 20, 2017 19:53:12 GMT -5
OK. Original equipment. You'll probably have to remove at least the bucket seat to get to it. Also, while you're in there you might as well switch to a manual fuel petcock. Like you said, there are walk-through abound here. Have fun. Keep it safe and reliable, and scoot on.
Post by jhill15 on Nov 29, 2017 20:10:14 GMT -5
Well it saddens me to say this, but I sold my scoot yesterday. It was a great starter bike but I will need something a little faster. So I will hang it up until the spring and see if I can find a 150cc.
Thank you all for everything, and all the help!
