Post by x7rocks on Mar 11, 2019 6:58:52 GMT -5
It will work.how long for is the question, I've done burst of speeds at 13k rpms with a stock crank,but figured it be a certain amount of time until it will bend from such high comp and rpms.
Post by ryan_ott on Mar 11, 2019 10:22:00 GMT -5
As long as you don’t have a bunch of miles on it and your bearings are within spec it’ll work but its life will be shortened. The cranks are actually pretty stout. 11k sure, continued use above 12k I’d limit.
Post by benji on Mar 12, 2019 22:39:52 GMT -5
As long as you don’t have a bunch of miles on it and your bearings are within spec it’ll work but its life will be shortened. The cranks are actually pretty stout. 11k sure, continued use above 12k I’d limit. I think there's about six thousand miles on this one. At least, on the case and the crank. Everything else has been replaced a couple times.
Post by benji on Mar 14, 2019 11:17:20 GMT -5
I'm looking at Athena Evolution Pistons because the kit I'm picking up is a 12 mm and my OEM crank is a 10 mm, and they have three different choices: a, b, and c. I'm assuming a is a normal piston, and B and C are for overbore?
Post by ryan_ott on Mar 14, 2019 12:33:06 GMT -5
I’m certain there is an “A” piston in there. Standard is usually “A” and each 10-15 thousandth over is the next letter up.
Post by benji on Mar 15, 2019 0:21:48 GMT -5
So, I'm crossing my fingers it goes thru ok, but I found a guy who'll ship me a set of jog rr wheels and a jog rr motor out of England. Shipping is killer, like $300 or so, but I'll be one of the only guys around with jog rr wheels! I'm such a geek haha.
Post by benji on Mar 16, 2019 6:29:48 GMT -5
Dunno if the wheels are gonna happen.. they are in real poor shape not sure if I wanna spend almost $500 on wheels and a motor if the rear wheel (at least) needs stripping and powder coating (if not refinishing) on another note, I've heard kx85 reed blocks fit minarellis with some "clearancing". Any body know about this?
Post by benji on Mar 16, 2019 18:52:48 GMT -5
Also, should I stretch it? Scooter tuning has the 3" stretch in stock and I'm making an order anyway.
Post by benji on Mar 16, 2019 19:36:54 GMT -5
Just made an order So I can install ryanotts parts. this stuff and Ryan's stuff should all show up around the same time I think.
Post by ryan_ott on Mar 16, 2019 19:51:53 GMT -5
You’ll have a busy week installing parts.
Post by benji on Mar 16, 2019 21:40:33 GMT -5
You’ll have a busy week installing parts. you think I should add a stretch kit to the order?
Post by ryan_ott on Mar 16, 2019 21:45:49 GMT -5
Your scoot is already low. I think with the stretch that will bring the pipe pretty low and it may not fair well on driveways. I personally would not but I know you like your stuff low so...
Post by benji on Mar 16, 2019 22:13:38 GMT -5
I was planning on using a longer shock to keep it the same height off the ground, but ya I already ruined one pipe. Maybe not right now.
Post by aeroxbud on Mar 16, 2019 22:33:07 GMT -5
Shame about the Jog RR wheels. I always found the handling quite good on the 12" wheels. Shipping is a killer on anything big. Not really sure what the difference is between the Jog rr, and the aerox engine. Yamaha quote different specs for both. The radiator on the Jog is tiny compared to the Aerox one. At least you will have some shiny stuff to bolt on.
Post by benji on Mar 17, 2019 19:11:29 GMT -5
Not really sure what the difference is between the Jog rr, and the aerox engine. Yamaha quote different specs for both. The radiator on the Jog is tiny compared to the Aerox one I know the Yamaha jog has a drum rear brake and the aerox is a disc, but other than that I'm not really sure.
