Post by benji on Mar 21, 2019 21:05:31 GMT -5
Got my threebond. I'm hoping my vforce3 stage6 reed block shows up tomorrow.
Post by 'O'Verse on Mar 21, 2019 23:46:37 GMT -5
Do you miss the abundant selection of medical grade marijuana that you had in Washington? In Arizona you might need a medical card. I bet there's tons of sub par doctors that'll just put a signature on a card for you for Under a $100. California you could get a card in the hood for like $80 that same day. Ahhhh the good ol days! 👍
Post by benji on Mar 22, 2019 0:27:03 GMT -5
Do you miss the abundant selection of medical grade marijuana that you had in Washington? nope yup, I had one in Washington. Time to get another.
Post by benji on Mar 22, 2019 1:14:30 GMT -5
See how the bottom of the piston and the boost port doesn't match? Should I make it match? I've got a Dremel tool. I'm gonna try to polish the exhaust port I think.
Post by ryan_ott on Mar 22, 2019 5:19:49 GMT -5
You could but you need to be careful not to chip the nikasil cylinder coating.
Post by pitobread on Mar 22, 2019 22:20:36 GMT -5
There is a lot of transfer port shrouding as well.
If you do tackle the nikasil use the diamond burrs.
Post by benji on Mar 22, 2019 23:27:44 GMT -5
There is a lot of transfer port shrouding as well. If you do tackle the nikasil use the diamond burrs. the sides of the cylinder skirt, right? Ya I'll pick up a couple new bits for this. I'm scared tho. I may not touch it, but I may go for it.
Post by benji on Mar 23, 2019 8:44:52 GMT -5
it looks great when installed. the double-edged sword that is stage6 products haha. Looks great, but be careful not to break it haha.
Post by benji on Mar 24, 2019 2:59:29 GMT -5
Got it mostly broken down.
Post by benji on Mar 24, 2019 3:01:13 GMT -5
I'm gonna try to clean up the frame since everything is off. I also might order some fresh plastics since it's all apart again.
Post by benji on Mar 25, 2019 10:08:19 GMT -5
Made an intake spacer out of my old reed block.
Post by benji on Mar 26, 2019 9:12:44 GMT -5
Cracked the damn plastic of the spacer I made out of the old POS reed block. I think I can glue it tho.
Waiting on some intake gaskets to show up before I bolt up the intake. Already have the cylinder installed and the squish is right (I think).
I'm gonna use a mikuni flatslide 24mm. The mikuni jets are numbered by flow rate instead of size, so I'm kinda shooting in the dark here. I'm gonna try a 32.5 pj and a 120 mj with 32:1 premix and a unifilter.
I just remembered I need a new spark plug. and cht sensor.
Post by jackrides on Mar 26, 2019 12:08:21 GMT -5
A couple things. Wouldn't a very fine stone then polish the grind with Cratex, have less chance of chipping the Nikasil? Next, regarding the pic at the top of page, don't you think that if you need a reed valve on the device you might be using it too much?
Post by tsimi on Mar 26, 2019 19:31:26 GMT -5
Cracked the damn plastic of the spacer I made out of the old POS reed block. I think I can glue it tho. The DIY force is strong in you. However you could just simply buy a spacer. They don't cost really much, something like $5-10.
Post by benji on Mar 26, 2019 20:21:32 GMT -5
you could just simply buy a spacer. Hahaha! Oh tsimi, you crack me up. That would be far too easy.
