Post by benji on Mar 26, 2019 20:24:34 GMT -5
They don't cost really much, something like $5-10. [/div][/quote] so, I actually went looking for some. The only one I could find was the most version that was angled, and I heard the holes don't line up right.
Post by tsimi on Mar 26, 2019 20:29:52 GMT -5
Post by benji on Mar 28, 2019 3:15:23 GMT -5
exactly. Friggin highway robbery. Well not really. But still.
Post by benji on Apr 2, 2019 1:37:36 GMT -5
All done bolting the motor together. I put the shrouds on after these pics. Squish seems right on (0.8mm-0.9mm) I think she's good. I still need to mod the case for the torsen arm, and mount the pipe.
Post by benji on Apr 2, 2019 20:59:03 GMT -5
The ziptie around the filter is for support. The carb was hanging on the boot and didn't seem good to me. I'm gonna end up getting a new filter anyways, I may come up with some kind of bracket to hold the carb more securely. Corrosion always used to tell me that carb boots would go bad regularly. The carb boot is an integral part of this manifold, if it goes bad I'll have to buy a whole new one.
Post by benji on Apr 6, 2019 18:54:08 GMT -5
Currently waiting on more parts. I ordered some jets and a choke cable adapter for the flatslide. Thinking about opening up the rear end and checking it out to make sure everything is good. Also thinking about changing the rear disc to a smaller 180mm rotor and bracket since this 190mm and bracket is slightly hitting the wheel.
Post by ryan_ott on Apr 6, 2019 19:47:59 GMT -5
You just need to recut a caliper adapter, I’m at 210mm and I clear, not by much, maybe .040” on the valve stem area. Did you cut into the case or just use an adapter?
Post by ryan_ott on Apr 6, 2019 19:50:00 GMT -5
The ziptie around the filter is for support. The carb was hanging on the boot and didn't seem good to me. I'm gonna end up getting a new filter anyways, I may come up with some kind of bracket to hold the carb more securely. Corrosion always used to tell me that carb boots would go bad regularly. The carb boot is an integral part of this manifold, if it goes bad I'll have to buy a whole new one. I used to have one of those on a different motor and mine started cracking in short order. The carb is too much weight on such a soft part.
Post by benji on Apr 7, 2019 8:36:48 GMT -5
You just need to recut a caliper adapter, I’m at 210mm and I clear, not by much, maybe .040” on the valve stem area. Did you cut into the case or just use an adapter? both, kinda. I ground the case flat and was able to make my own bracket. You may be right- I may be able to re-clock the caliper to get it to clear. The brake line bolt is just barely touching the wheel as it rolls.
Post by ryan_ott on Apr 7, 2019 8:40:27 GMT -5
You might be able to slot one hole slightly to rotate it in and gain some clearance.
Post by benji on Apr 7, 2019 8:46:40 GMT -5
Post by benji on Apr 7, 2019 8:47:35 GMT -5
You might be able to slot one hole slightly to rotate it in and gain some clearance. I think your right, but I wanna make sure the pad is still seated right. I should probably get new pads too.
Post by benji on Apr 7, 2019 8:49:45 GMT -5
I'm kind of proud of the rear disc. I did it myself, and I get a lot of comments on it when I take it to rides. 😁
Post by ryan_ott on Apr 7, 2019 9:01:06 GMT -5
I’ve got a love/hate relationship with mine. Love the way it looks, stops great but pads only seem to be available in the UK, and the cases are purpose cut. You can’t really recut your cases so I’d try to rework the bracket. This is what I came up with (thicker bracket now)
Post by benji on Apr 7, 2019 9:35:03 GMT -5
All I had at the time was a 4" grinder/cut-off wheel :/ I've gotta nice Dremel tool now, but if I was gonna redo it id either do a conversion hub and keep the drum brake or I'd use an aerox case.
To be honest, I've actually noticed a difference in Rolling resistance between the heavier disc brake bikes and the lighter drum brake bikes. My old prebug was way quicker off the line just cuz it rolled very easy, and it had front+rear drums. Drums have no rolling resistance compared to discs, that constantly drag the pads on the rotor.
