Post by jbjhillbilly on Sept 2, 2018 13:36:04 GMT -5
It's the 4 valve. They are different size. Copy that.
Post by Happypancake! on Sept 10, 2018 13:08:49 GMT -5
Valves arrived
Post by Happypancake! on Sept 23, 2018 13:45:46 GMT -5
Here’s what a piston looks like when your exhaust valves don’t fully close. Even with new exhaust valve there was zero clearance to shim. I ended up grinding down the end of the rocker to gain clearance. Runs smooth now.
Post by Happypancake! on Sept 24, 2018 20:48:45 GMT -5
Gear swap time !
Post by Happypancake! on Sept 28, 2018 19:17:26 GMT -5
GETting there. Red spring time. Only at 9200 rpm
Post by spazter12 on Sept 28, 2018 21:19:22 GMT -5
Black magic! lol
#batterbuilt
Post by jbjhillbilly on Sept 29, 2018 17:25:00 GMT -5
Nice! So the Aero gears are out, and the Met gears are in, correct?
Post by Happypancake! on Sept 29, 2018 17:51:56 GMT -5
Yes sir. Just the tall one. May drop to all Ruck as rpms too low.
Post by jbjhillbilly on Oct 1, 2018 3:42:17 GMT -5
Yes sir. Just the tall one. May drop to all Ruck as rpms too low. I'll be interested for the next steps. And now that I'm between shows again, I can un-stall my build(s)! *It's funny, that for all the other math I GET intuitively, when gearing comes up, the inverse numerical qualities coupled with ratios, have always made my brain shrug. Same with odds at the horse track (and my dad is a more than competent gambler). I understand it, but it doesn't land in my subconscious like other stuff.
Post by Happypancake! on Oct 13, 2018 9:36:19 GMT -5
Red spring in. Shifting moved up to ~8400rpm. Waiting for spring to break in a bit
Post by Happypancake! on Dec 8, 2018 13:41:20 GMT -5
Swapped the 2 Bros for a Yoshi.
Post by spazter12 on Dec 29, 2018 14:05:07 GMT -5
Did the turtlehead white match the rear frame white?
Post by lilpinny on Dec 29, 2018 14:26:59 GMT -5
Looks good!
Post by Happypancake! on Dec 29, 2018 14:27:27 GMT -5
Color is close. The bad news is that waffle is so low a plate wont fit in that spot.
Post by lilpinny on Dec 29, 2018 14:30:55 GMT -5
Slap it on the side of the engine
