Post by devhour3d on Mar 21, 2018 18:23:54 GMT -5
Maybe I should start looking for a Ruck, this is giving me evil thoughts. I agree! I'm thinking about one too, however i may go the route of buying both halves of the frame and working up from there. There's only one ruck for sale in my area not from a dealership and they want $3700 for an o9 with 1600 miles clocked. Its not even dressed or built up, just bone stock. And i hijacked the thread. Mr Tydeancustoms, i love the amazing detail you show in your build here, and this is such a great insight to a less than traditional workup of a ruck! I really enjoy builds that go beyond bolt-ons because of the magic trickery a good fabricator can accomplish! Sorry to keep the hijack going Ty, guys keep in mind it might be cheaper to get a Honda Met and buy a ruck rear frame and a few other parts to turn it to a ruck. Or you could just buy a ruck rear frame a battery holder and a ruck swing arm and have yourself a metruck. Because the front frame is the same, you have some options.
Post by tydeancustoms on Apr 7, 2018 10:52:50 GMT -5
Appreciate the comment.
No worries.
Post by tydeancustoms on Apr 7, 2018 11:02:23 GMT -5
Work continues. Tab for coolant bottle. Tabs welded to motor mount link for fuel pump.
Post by spazter12 on Apr 7, 2018 11:03:35 GMT -5
This looks so good! 🍿
Post by tydeancustoms on Apr 7, 2018 11:07:13 GMT -5
The motor mount will not only hold the fuel pump but all of the Helix electronics. So a variety of tabs and bolts will be welded to the motor mount. Everything pictured will be installed on the motor mount.
Post by tydeancustoms on Apr 7, 2018 17:53:38 GMT -5
Upper and lower radiator mounts fabricated.
Post by tydeancustoms on Apr 11, 2018 18:25:02 GMT -5
Started working on the shock mount last night.
Post by tydeancustoms on Apr 12, 2018 20:19:01 GMT -5
Post by tydeancustoms on Apr 13, 2018 14:06:35 GMT -5
Post by tydeancustoms on Apr 13, 2018 18:33:10 GMT -5
Also started on the drag brace today.
Post by tydeancustoms on Apr 14, 2018 20:37:51 GMT -5
Shaved the swingarm Exhaust/header mock-up
Post by tydeancustoms on Apr 15, 2018 17:41:33 GMT -5
Post by tydeancustoms on Apr 17, 2018 18:08:14 GMT -5
Post by Happypancake! on Apr 17, 2018 18:42:40 GMT -5
Not fun. I use the same method. Then set the bead w/ Heat.
Looking good btw!
Post by tydeancustoms on Apr 18, 2018 8:43:07 GMT -5
Thanks Happy. Last night I did some work on retrofitting the Helix ignition to the Ruck. Cut the Helix mounting bracket, 90 degree bracket will be welded in place to join the Ruck and Helix brackets together.
