Post by spazter12 on Sept 6, 2018 17:12:43 GMT -5
Post by spazter12 on Sept 7, 2018 1:57:25 GMT -5
I'm getting WAY ahead of myself but I want to do this to my CVT once I tune it. And paint the clutch bell with that red I used on the engine mount. The poor man's anckle biter 😂😂
Post by spazter12 on Sept 9, 2018 16:20:25 GMT -5
Post by spazter12 on Sept 10, 2018 11:38:24 GMT -5
May have found one of the issues... They're all like that Definitely not GETting full potential out of this CVT
Post by lilpinny on Sept 10, 2018 12:24:37 GMT -5
I'm getting WAY ahead of myself but I want to do this to my CVT once I tune it. And paint the clutch bell with that red I used on the engine mount. The poor man's anckle biter 😂😂 dunno about poor mans, that powdercoat on the cover is some coin
Post by spazter12 on Sept 10, 2018 12:51:12 GMT -5
dunno about poor mans, that powdercoat on the cover is some coin I was looking more at the open clutch bell, less the paint job lol
Post by spazter12 on Sept 11, 2018 9:59:57 GMT -5
*Weather 79F Humidity 88%* Carb settings: Main jet - 110 Idle jet - 32 JJK needle - e clip in the middle Idle screw - all the way in then ½ turn out 13g sliders in the variator. (Might be too heavy) 47mph at 7000ish? rpm (Was just cruising to charge up the battery so I didnt see when it actually happened) Got to that speed somewhat slower than before, but I feel like if i had more road incouod GET to a higher top end. There seems to be a bit more room on the variator. I'm afraid the may be a slight groove preventing me to GET further out. Saw the marker trick on one of @90gtvert 's videos so I gave it a try. It started raining again so I'm going to try to set up lilpinny 's wideband to see if I can actually GET some good progress once is a bit more dry outside.
Post by spazter12 on Sept 11, 2018 11:24:23 GMT -5
Stopped raining and just as I was done setting up the wide band the roads dried up #texasweather Here is the wide band set up: This part is obvious. Welded on the O2 bung a while back so I could screen in the wide band. Since this isn't a permanent set up, I don't need it to be perfect, but I do need it to be out the way and safe. Thank God for zip-ties, they gotta be my favorite mod tool lol Like I said before, not permanent but still needs to be functional and out of the way. I have a battery tender and I bought a USB charger that plugs into the outlet. It came with an extra wire that I don't use so I modded lilpinny's set up a bit so I didn't have to carry his baby ballistic battery with me #loseweightgofast lol
Post by spazter12 on Sept 11, 2018 11:34:00 GMT -5
The set up worked like a charm. I took it on its maiden vollage to GET a tag.
What did I learn? Holy shit was I clueless.
When I give the ruck more than ¼ to ⅓ throttle the gauge dips below 12. Any thing more that ⅓ throttle and it dips even more.
At WOT I get 47ish mph bit 9.3 on the gauge so that may be where my issues lie.
I'll be downjetting today so I'll report back
Post by spazter12 on Sept 11, 2018 14:40:09 GMT -5
*temper 80F Humidity 81% *
Carb settings: Main jet - 105 (down from 110) Idle jet - 32 JJK Needle - E clip in the middle Air fuel screw: ¼ turn out from tight
After riding around for enough to warm up the engine here are my findings.
Idle to ¼ throttle: Stays above 13. When throttle is released while slowing down I see 18-19ish
Mid-range: 10.2-11.5
WOT: Leans out to around 11.8-12.1
Thoughts on next steps: -possibly go from 32 to 35 on the idle jet to richen out the idle -move the e-clip on the JJK needle up one to restrict it a bit and lean out the mid range
Those two changed will be done one at a time
Post by Happypancake! on Sept 11, 2018 14:40:26 GMT -5
I’d say you’re a tad rich. ......::
Post by spazter12 on Sept 11, 2018 14:42:37 GMT -5
No kidding. I was running a 115! Lol
Post by Happypancake! on Sept 11, 2018 15:04:04 GMT -5
Don’t need no stinking afr. Tune w/ seat of pants.
Post by spazter12 on Sept 11, 2018 15:11:45 GMT -5
I feel like once I know what I'm looking for it would be easier. First time tuning with out one I was way lost. Thought I needed more fuel. BTW you the man Happypancake!. I never doubted you
Post by lilpinny on Sept 11, 2018 15:30:35 GMT -5
Stopped raining and just as I was done setting up the wide band the roads dried up #texasweather Here is the wide band set up: This part is obvious. Welded on the O2 bung a while back so I could screen in the wide band. Since this isn't a permanent set up, I don't need it to be perfect, but I do need it to be out the way and safe. Thank God for zip-ties, they gotta be my favorite mod tool lol Like I said before, not permanent but still needs to be functional and out of the way. I have a battery tender and I bought a USB charger that plugs into the outlet. It came with an extra wire that I don't use so I modded lilpinny's set up a bit so I didn't have to carry his baby ballistic battery with me #loseweightgofast lol thats what i did. just zip the excess length
