Post by lilpinny on Apr 30, 2018 12:01:41 GMT -5
Sweet.
Post by spazter12 on May 22, 2018 23:49:34 GMT -5
While I wait for the rest of the parts for the carb swap I decided it was time to work on the stock carb, specially since I had some jets laying around. Istripped one of the screws from the bowl trying to take them off. G'damn it! After some tinkering, I was able to take the bowl off just to find unmarked jets. I had a 40 pilot jet so I put it in. I'll test drive it in the morning to see if there are any changes
Post by spazter12 on May 24, 2018 10:09:19 GMT -5
Went for a ride yesterday and broke down even closer to home than with the stock jets.
Next up: -put old jet back in -check for any vacuum leaks -burn the fuckus to the ground. (Only half kidding at this point)
Rucksanne needs an oil change as well, she's a bit overdue for one.
Rucksanne
May 24, 2018 10:55:02 GMT -5
via mobile
Post by benji on May 24, 2018 10:55:02 GMT -5
I'll trade you for my non-running met haha.
Post by spazter12 on May 24, 2018 11:00:19 GMT -5
Haha. Very tempting lol
Post by lilpinny on May 24, 2018 11:21:02 GMT -5
Spend all that time earning some money for a harness and do the swap right...
Get out there and mow some lawns!
Post by spazter12 on May 24, 2018 14:44:17 GMT -5
Get out there and mow some lawns! Thought about that. But got some debts to pay before I can put any money on to the ruck. Hence why the cheap parts for the carb upgrade are making the swap take so long.
Post by Happypancake! on May 24, 2018 16:27:21 GMT -5
And I have a spare GET motor if u need it....
Post by lilpinny on May 24, 2018 16:27:57 GMT -5
I want a GET. Ruck or met?
Post by spazter12 on May 24, 2018 16:29:20 GMT -5
And I have a spare GET motor if u need it.... Tought about that too... I'll let you know Happypancake!. Thanks 🙏
Post by lilpinny on May 24, 2018 16:36:59 GMT -5
And I have a spare GET motor if u need it.... Tought about that too... I'll let you know Happypancake!. Thanks 🙏 You can't go back to a GET, you'd need to change the mount, it'd screw up all your spacing, OEM harness and a new rear wheel. You've taken then GY6 path, only one way... Forward. Don't let the GY6 Beat you, beat the GY6.
Post by lilpinny on May 24, 2018 16:37:48 GMT -5
GY6 1 - Spaz 0 so far 😀
Post by spazter12 on May 24, 2018 16:39:17 GMT -5
Yeah, let's say that's the score 🤣😂
Post by lilpinny on May 24, 2018 16:39:58 GMT -5
Yeah, let's say that's the score 🤣😂 I'm being kind just giving the GY6 1 😜
Post by spazter12 on May 24, 2018 16:54:17 GMT -5
$5 fix? Stay tuned to find out #fixthemvacuumleaks
