Post by Happypancake! on May 24, 2018 17:43:30 GMT -5
If that doesn't work JB WELD!
Post by spazter12 on May 24, 2018 17:53:14 GMT -5
I'll have to wait on JB WELD until the new manifold comes in.
Post by lilpinny on May 24, 2018 18:06:23 GMT -5
My God no JB Weld. Use RTV between the intake and the head. Follow the instructions and a little goes a long way. Also make sure to file your clocking flange a little so it doesn't bump up against the forward part of the head. If you don't it won't sit flat. Couldn't get imgur to bring up this old image so a screen shot See where it bumps up a little? That'll.mess it up
Post by lilpinny on May 24, 2018 18:10:43 GMT -5
You gotta shave a 45 degree angle on that edge on the manifold, not the head, so it'll sit flat .
Post by spazter12 on May 24, 2018 18:39:15 GMT -5
You gotta shave a 45 degree angle on that edge on the manifold, not the head, so it'll sit flat . Hmm... That could be where my problem lies. I never did that when I got the aluminum intake. I ordered a small torch to heat up the bolts, red locktight will be the death of me. Lol
Post by lilpinny on May 24, 2018 18:41:07 GMT -5
You can kinda see where it's shiny on the head where it bumps up. Took me a while to figure that out too. TRS told me about it. Sure as shit it was the problem
Post by spazter12 on May 24, 2018 19:32:59 GMT -5
I'll try to do it tonight. Hopefully I get a chance to
Post by spazter12 on Jun 6, 2018 15:12:34 GMT -5
Finally got some time to look at the ruck. I found a pinched O-ring, Might be part of the problem.
Post by lilpinny on Jun 6, 2018 15:23:31 GMT -5
Eureka!
Good chance that could be it. Doesn't take much
Post by spazter12 on Jun 6, 2018 15:38:52 GMT -5
Had to recruit some help to get the red locktight bolts out. Homeboy doubles as a soldering iron too! 🤙🏼 If you look closely there's a storage rolling bench in the background. Father's day present I'm not allowed to open yet. #pardonthemess
Post by lilpinny on Jun 6, 2018 16:17:17 GMT -5
I bet that o ring is your problem. Just the way the leak only pops up once you are going... Holds a seal when you start it as it really starts sucking the o ring fails with a pin hole leak and it goofs up. Hope you can find an o ring that'll fit. Worse case an intake is $12
Post by spazter12 on Jun 6, 2018 16:31:51 GMT -5
I bet that o ring is your problem. Just the way the leak only pops up once you are going... Holds a seal when you start it as it really starts sucking the o ring fails with a pin hole leak and it goofs up. Hope you can find an o ring that'll fit. Worse case an intake is $12 Would the RVT be enough to remove the o-ring? Is my time using it and Google has given me both thumbs up and thumbs down on chunking the o-ring
Post by lilpinny on Jun 6, 2018 17:05:24 GMT -5
I think you should use both, if that o ring wasn't messed up. If you Chuck the o ring it sounds like it should work. Worse case you are back to where you started.
That's clocking flange right? I might have an old one. I can look.
Post by spazter12 on Jun 6, 2018 17:08:56 GMT -5
Yeah it's a clocking flange. I'll have to get a new intake and maybe clocking flange for the new carb. I barely clear the frame crossbeam upfront.
Thanks 🤙🏼
Post by lilpinny on Jun 6, 2018 17:11:12 GMT -5
I barely clear it too. The foam on the uni filter is right up against it.
