kglazer
Post by kglazer on Aug 7, 2011 17:32:26 GMT -5
Thats what i was thinking 3 tanks and if everything is fine at 32:1 i will keep running it. Would it ever make sence to switch to 40:1 just to see about better performance?
Post by 90GTVert on Aug 7, 2011 18:40:05 GMT -5
I doubt you'll see much difference in 32:1 and 40:1. I just choose a ratio and stick with it from day 1 for my builds. There's a lot of personal preference involved in break in procedures and oil choices.
kglazer
Post by kglazer on Aug 7, 2011 18:53:08 GMT -5
I will stick to the richer setup just to be safe
mccanic
Post by mccanic on Aug 7, 2011 23:58:21 GMT -5
good idea! keep using the same type of oil to
kglazer
Post by kglazer on Aug 8, 2011 0:04:13 GMT -5
Yep. I might want to add a racing filter and ditch the stock air filter for the looks of nothing covering the rear whe since i took the fender off and the little added performance. Would the 90 jet be to small for it?
Post by reveeen on Aug 8, 2011 2:55:17 GMT -5
Leave things as they are for your break in.
I'm in danger of being a do as I say, not as I do, kind of guy here. With your stock carburetor, in it's stock location, you will do no better than with your stock air box. When the situation dictates, meaning: the stock air box no longer fits, then you have to look at other ways of filtering your air.
Here is why: 1) a stock air box does an excellent job of keeping the rain/road splash, and dirt, out of your engine, ESPECIALLY for those who have removed the rear inner fender. 2) A K+N, or the sock, type of filters require regular maintenance (cleaning and oiling). On a scooter the filter is close to the ground and if you don't oil it (to trap the dirt) you might as well run a velocity stack with a coarse screen. Once the dirt is trapped you must wash the dirt out regularly, and re-oil. 3) Your carburetor, as it's set up now, is set up to use the air box, remove it and you are into a whole world of pilot jets, main jets, and possibly needles, are you prepared to go here?
Typically, about a 40 pilot jet, a main jet about 100+ are required, with some luck you can juggle your stock needle.
mccanic
Post by mccanic on Aug 8, 2011 6:54:00 GMT -5
very good right up reveen! Like he said leave that alone, if its broken get another.
kglazer
Post by kglazer on Aug 8, 2011 11:02:53 GMT -5
Ok sounds good i def leaving thw stock airbox. Im a person that believes function over looks is the way to go. I didnt know its that much of hassel lol.
kglazer
Post by kglazer on Aug 8, 2011 20:44:44 GMT -5
Will there be any problems like overheating or anything running the technigas next r pipe with the malossi 70cc kit. I have to save up for the rs2.
mccanic
Post by mccanic on Aug 8, 2011 21:48:48 GMT -5
get a 50cc pipe. the stock crank can't take the rpms that, that pipe will make.
kglazer
Post by kglazer on Aug 8, 2011 22:00:22 GMT -5
The technigas next r is a 50cc pipe i have been runing it on my 50cc all summer. the rs2 is the 70cc pipe in technigas lineup. I have the stock pipe but prefer the weight savings of the next r.
mccanic
Post by mccanic on Aug 8, 2011 22:25:14 GMT -5
oh sorry i read that wrong lol, no you will be fine running that pipe, i would save to buy the motoforce evo crankshaft, and get the next r!!
kglazer
Post by kglazer on Aug 8, 2011 22:35:33 GMT -5
Could you send me the link to the cranckshaft and what does upgrading the crankshaft do? Do u mean save up for the rs2 i have the next r already?
mccanic
Post by mccanic on Aug 9, 2011 6:13:51 GMT -5
Post by 2strokd on Aug 9, 2011 6:21:51 GMT -5
Just how high do you think your gonna rev lol? Ive pushed OEM cranks ever 11,000RPM many times with many miles and never broke one. Maybe i was lucky hehe?
