kglazer
Post by kglazer on Aug 18, 2011 13:20:16 GMT -5
ok. does it matter the thickness of the gasket do i need to measure the thickness of the malossi one? can i trace the original gasket? or do i have to do it like 190mech
Post by 90GTVert on Aug 18, 2011 13:22:37 GMT -5
You can trace the old one. Thickness does matter. Doesn't have to be exact, but should be close.
kglazer
Post by kglazer on Aug 21, 2011 13:47:12 GMT -5
hey guys everything went in smoothly unfortunitly i could not get any pitures i forgot it on my way to the garage. we didint have enough time to upjet im going to do it tuesday night. i did drive it though and it wouldnt go over 30mph or let me go past half throttle it just bogged and didnt really accelerate to fast so im assumming this is due to the stock jet in correct?
tango
Ad agendum semper parati
Post by tango on Aug 21, 2011 13:58:19 GMT -5
Sounds like it was soft seizing, which you would have expected. Expect a better run once you jet properly. Also, I would recommend you stay away from 30mph+ runs until you do. Even soft seizing can hurt the engine.
kglazer
Post by kglazer on Aug 21, 2011 14:03:34 GMT -5
yeah jsut to get it home since i couldnt leave it at the garage. the only other time im riding it is back to the garage and willl go slow to try and not to soft seiz it
kglazer
Post by kglazer on Aug 21, 2011 23:46:07 GMT -5
will soft seizing cause any bad problems? like for the 15 mins i rode it avoiding it going more then a quarter throttle? like take the head off and check it?
Post by 90GTVert on Aug 22, 2011 11:21:42 GMT -5
I don't think you soft seized it. The engine would stop. I think your jetting is just wrong.
kglazer
Post by kglazer on Aug 22, 2011 12:18:46 GMT -5
O the motor definitly never stopped but im not riding it until the jetting is right though. Im gonna try a 85 jet first since i have a 90 and 82 jet so i can go up or down according to the plug
kglazer
Post by kglazer on Aug 22, 2011 19:54:34 GMT -5
kglazer
Post by kglazer on Aug 23, 2011 12:48:41 GMT -5
any help guys?
kglazer
Post by kglazer on Aug 29, 2011 19:12:28 GMT -5
hey guys GREAT NEWS i got the 88 jet installed and shes running. im still breaking her in and have been keeping it 1/4 throttle and a few high rev pulls!!!! which are amazing the torque. i have 5 gram rollers in there now. im thinking with the new power i should go a little heavier weights since the power curve is diffrent and its probably revving to high now? what is the ususal gram size that people run in 2 stroke 70cc's
Post by 90GTVert on Aug 29, 2011 19:27:11 GMT -5
Roller weight varies depending what gearing is and other factors. If it's running well now you probably won't have to go much higher in weight. You could pick up a set of 6g weights and then you'd have the option to use 5, 5.5, or 6g. If you feel like it's way light, maybe get a set of 7s and you can mix to make 5, 6, or 7g.
kglazer
Post by kglazer on Aug 29, 2011 21:37:19 GMT -5
yeah i could i kinda like how it revs now. i was was thinking to put a stiffer contra spring in to help to since i have 1000 now mayb ill switch to 1500 or 2000 since i have them in the garage that would help?
Post by 90GTVert on Aug 29, 2011 22:21:40 GMT -5
That would make it rev even higher.
kglazer
Post by kglazer on Aug 29, 2011 23:03:49 GMT -5
Oh well then nevermind. I guess ill rlly wait till break in to start messing with it since then i can tune it to its full potential
