Post by aeroxbud on May 20, 2021 2:59:33 GMT -5
That's the one. I'm sure if a garage had one of those, it would get it out.
Post by scooternub on May 20, 2021 6:54:46 GMT -5
I was thinking about the same thing a day ago or so, air impact hammer living on the edge I'd say using this even with a socket. Scary thinking this going through the block 😖
df41590
Post by df41590 on May 20, 2021 13:55:43 GMT -5
I was thinking about the same thing a day ago or so, air impact hammer living on the edge I'd say using this even with a socket. Scary thinking this going through the block 😖 They have a semi-variable throttle so you can ease into it. You can also adjust how hard it hits at least on the Mac one I have. You would need to be cautious about mushrooming the tip b/c these things are beasts which I guess wouldn't be a big deal as long as it didn't get stuck in the socket you can always cut/grind off the mushroomed bit once you get the pin moving, but using a socket would prevent it from hitting the aluminum if the bit slipped off the pin.
