Post by birdman on Aug 4, 2019 23:42:54 GMT -5
Post by birdman on Aug 5, 2019 0:08:30 GMT -5
My setup as it sits now: Polini corsa 70cc bbk Polini for race 4 pipe (thanks PIG ) Doppler S1R crank (10mm) Malossi OR Stage 6 intake manifold Dellorto 21 (stage 6 version) UNI pod filter Bando coil w/ ngk cr2 lead Stock gearing My plans: 1)do some carb tuning my cvt feels great as it is with 5g weights and a malossi yellow contra. The jetting on the carb actually feels good as it came out of the box but I have mains to play with (90-99). Idle is great, then I'll dial in the main, and then do the pilot. This is my first venture with dellorto phbg I'm used to using pwk/ oko so there will be a learning curve. 2) a matching bopper for the front is on order to replace the rotting reggae. 3) add a little farkle with a little chrome accents on the engine [/url] 4) paint the wheels so they match, still thinking of a color (your input is welcome) 5) maybe do a front disk and naked bar setup with 12in wheels later down the road,
Post by tsimi on Aug 5, 2019 1:53:47 GMT -5
Can you plz take a picture straight from the rear? I would like to see how close the pipe sits to the rear wheel.
Thx
Post by birdman on Aug 5, 2019 2:35:27 GMT -5
Here you go tsimi. For reference it's a 130/90-10 size tire, and I installed the pipe without spacers or any other modifications.
Post by tsimi on Aug 5, 2019 3:30:06 GMT -5
Thank you.
Post by birdman on Aug 26, 2019 20:48:16 GMT -5
Did a little tuning, I put a 99 mj and it feels a little rich but good. I took it for a few laps around town and my plug looks like this What do you all think of that? I may go to a 97 or 98, I still need to order a set of pilot jets too. Also I edited my previous posts, it's a dell 21 not a 19.
Post by geoffh on Aug 27, 2019 14:08:34 GMT -5
Looks rich but rich is safer than lean, are you running a temp and rev gauge or tuning by "ear".
Post by birdman on Aug 27, 2019 20:59:00 GMT -5
I'm just tuning by ear and feel. Using the choke as a guide when I'm tuning for a particular throttle position. Since this is my first go with a Dell I'm going to order a temp Guage come friday/ payday to end all the guess work and do it right.
Post by hellish100 on Aug 27, 2019 21:48:30 GMT -5
Do folks not like the corsa?
Post by birdman on Aug 28, 2019 10:36:17 GMT -5
Do folks not like the corsa? Me personally, I'm an advocate of the corsa! Some here may feel it's overrated as a cylinder... At least that appears to be the consensus around here.
Post by hellish100 on Aug 28, 2019 21:28:47 GMT -5
Thanks! When I’m ready to get a 70 kit, I was considering the corsa or the malossi cast: sorry to hijack!
Post by 'O'Verse on Aug 28, 2019 21:35:01 GMT -5
I’m a firm believer in Corsa. But mostly on a Honda platform. I think there seeing better results than us horizontal / Vertical minarelli guys....
Post by repherence2 on Aug 28, 2019 21:40:58 GMT -5
do you go off road with it? im asking because I see the big tires. if you don't go off road, that bike might be more fun/fast on 3.00 x 10 tires.
Post by repherence2 on Aug 28, 2019 21:49:44 GMT -5
the Corsa is the bore of choice in the Honda platform here on Oahu. Those bikes are pretty damn fast. they even run Corsas with ministroker cranks. I'm so impressed/baffled with the Honda Corsa combo, that I just bought me a used SYM dd50 engine so that I can rebuild it for a Corsa. I don't even have a bike for the engine yet. I just want to see what makes the Hondas here on Oahu so fast.
Post by birdman on Aug 28, 2019 22:44:53 GMT -5
I have a corsa on my honda and it rips hard, it's been going strong for almost 20,000 miles over the past 5 or so years. How great it does on my honda is why I got it for this platform to see if it's anywhere nearly as potent. Also smaller wheels on this thing would kill my top speed and I would probably loop this thing off the line everytime.
