Post by milly on Oct 5, 2019 13:55:10 GMT -5
Post by jloi on Oct 5, 2019 14:42:19 GMT -5
Milly, can you put up a link where you got the grips and the headlight ? thanks . looooking gooood
Post by jloi on Oct 5, 2019 14:44:17 GMT -5
is this early xmas or what ?
Post by milly on Oct 5, 2019 15:07:23 GMT -5
Milly, can you put up a link where you got the grips and the headlight ? thanks . looooking gooood Will do most likely very soon if not when home on computer. Headlight was a one off a shop put on ebay didn't see anymore listed
Post by milly on Oct 5, 2019 15:09:51 GMT -5
Post by jloi on Oct 5, 2019 15:38:37 GMT -5
thanks Milly, how do you like them? do ya think they'll be easy to clean? mine get soo dirty. just plain black rubber. clean with ajax liquid.
I remember seeing some other posts recently with good looking grips- similar to yours. price is right
Post by milly on Oct 7, 2019 15:39:21 GMT -5
Not sure about the cleaning bit I dont do that very often on mine jloi
Post by milly on Oct 7, 2019 15:47:29 GMT -5
Well today I took my son's belt cover off so I can see what weight rollers and contra spring I put in his as that one is pretty pokey with the 80cc bbk kit on and checked carb needle position and jet size. I wish I had made notes when I did it a couple year ago, just gotta put it together now. I have a new 80cc bbk sitting in a box of bits which will go on when engine arrives and I have a spare couple of 80cc heads hanging about which needs valves checking and since buying a valve compressor will make job easier. I found an identical carb in another box of bits and I have a jet from my jet set so only looks like a head gasket set and away we go.
Post by milly on Oct 8, 2019 12:23:44 GMT -5
Changed jet in the spare carb. Carb looks like a new one I never used and found the head when the stray cat came in the shed to hunt mice and the A9 cam. All I got to do now when back from work on Saturday is remove valves and grind in once done friends Ford Transit and her bicycle. Plus I found some new variator rollers once I weighed the ones took out my sons scoot and head gasket set on way.
Post by milly on Oct 10, 2019 15:16:48 GMT -5
Home after a 3 hr drive from work and engine arrived, been outside in the rain but got it over the garage so work on it after work tomorrow . Blooming hot having to wear a waterproof coat because of rain and wind this evening sweat like mad its so humid with all the heat 59f and rain would have thought the winds would have cooled things but nope.
Post by aeroxbud on Oct 11, 2019 0:59:09 GMT -5
And so it begins! 😁 Feeding the addiction. 😉
Post by milly on Oct 11, 2019 8:04:09 GMT -5
And so it begins! 😁 Feeding the addiction. 😉 I can neither confirm or deny that comment. I think I might make a good politician with that comment. 😝
Post by milly on Oct 11, 2019 13:23:37 GMT -5
Post by milly on Oct 14, 2019 11:41:25 GMT -5
Engine build coming along 80cc barrel fitted A9 cam fitted. After measuring the cams to find out which was which I noticed A9 printed on it.
Post by jloi on Oct 14, 2019 13:43:14 GMT -5
for once , fine print worked out good.
