Post by milly on Sept 28, 2019 9:42:50 GMT -5
Well instead of bits dotted about all over the forum I shall start one thread and maybe place all the other bits in it so far I have done a 70cc bbk and crank Naraku stuff, new oil pump mucked about with new belt and weight etc and have now started chopping and changing it again. The scooter started life as two non runners for approx £50. One I done for my son out all the good bits but thats another thread later since he gave it back to me. This one out of all the left over bits and then slowly chopped and changed.
AS WAS BEFORE THE LATEST INCARNATION
FITTING THE NEW BITS LAST WEEK OR SO
FINAL BIT OF BODGE WELDING AND ROAD TEST (all went well )
PUT AWAY TILL BACK FROM HOLIDAY
Post by jbjhillbilly on Sept 28, 2019 12:40:14 GMT -5
That headlight placement is genius!
Post by milly on Sept 28, 2019 13:14:21 GMT -5
That headlight placement is genius! Just happened to be a convenient bracket after removing the plastic and no drilling needed 😊
Post by jloi on Sept 28, 2019 14:22:18 GMT -5
that's a great light and brand new speedo. Milly , I don't see your latest acquisition - the one with all the character, ie. , stickers etc.
Post by milly on Sept 28, 2019 15:06:02 GMT -5
that's a great light and brand new speedo. Milly , I don't see your latest acquisition - the one with all the character, ie. , stickers etc. Ah jloi I did not go for it in the end, being sensible with what I already have and do my own build.
Post by milly on Sept 28, 2019 15:12:08 GMT -5
NEW SCOOTER SEAT AND SADDLE BAGS. JUST NEED TAKE IT TO BLACKSMITH TO WORK HIS MAGIC AND FIT FRAMES EACH SIDE SO I CAN REMOVE AMMO BOXES WHEN NEED TO AND FABRICATE A FRAME WITH ADJUSTMENT FOR THE OLD TRACTOR SEAT AS MY WELDING WORSE THAN SEAGULL DROPPINGS
Post by jloi on Sept 28, 2019 22:56:35 GMT -5
Oh , I thought the other one was a done deal .
does that thing have springs under it ?
Post by jackrides on Sept 29, 2019 15:13:58 GMT -5
At least it has a hemorrhoid plug. Probably should have an acorn nut in place of the bolthead.
Post by milly on Sept 29, 2019 17:14:14 GMT -5
Oh , I thought the other one was a done deal . does that thing have springs under it ? No springs need sort out something 😊
Post by milly on Sept 29, 2019 17:15:08 GMT -5
At least it has a hemorrhoid plug. Probably should have an acorn nut in place of the bolthead. Maybe a cushion would be better 😝
Post by jloi on Sept 30, 2019 12:07:31 GMT -5
" No springs need sort out something 😊"
yes, well in that case the good news is your options are infinite . Hmmmm, I wonder if clutch springs would work; a bit stiff I would imagine .
Post by milly on Oct 1, 2019 15:27:59 GMT -5
May have the answer jloi with an inner tube if needed
Post by jloi on Oct 3, 2019 11:35:15 GMT -5
I think that's actually not a bad idea .you could work some sort of covering
Post by milly on Oct 5, 2019 10:16:47 GMT -5
Post by aeroxbud on Oct 5, 2019 10:26:30 GMT -5
It's getting some bling now. 👍
