Post by gy6luver on Oct 2, 2011 18:56:06 GMT -5
lol im getting mixed messages lol
Post by speedy1125 on Oct 2, 2011 19:06:50 GMT -5
lol im getting mixed messages lol Skip the part on that tire thread where he actually takes the tires off. Do this by an air compressor at a gas station, a friend who has an air compressor...whatever. Step one: remove the core to let the air out. Step two: using the clamp I showed, squeeze the tire together by the hole where the stem goes Step three: cut the old stem out Step four: remove the core from the new stem Step five: install new stem Step six: remove clamp Step seven: shoot air into the tire to set the bead Step eight: screw the core back in Step nine: inflate to 40 psi Step ten: drive on your way
Post by gy6luver on Oct 2, 2011 19:08:45 GMT -5
Skip the part on that tire thread where he actually takes the tires off. Do this by an air compressor at a gas station, a friend who has an air compressor...whatever. Step one: remove the core to let the air out. Step two: using the clamp I showed, squeeze the tire together by the hole where the stem goes Step three: cut the old stem out Step four: remove the core from the new stem Step five: install new stem Step six: remove clamp Step seven: shoot air into the tire to set the bead Step eight: screw the core back in Step nine: inflate to 40 psi Step ten: drive on your way seems easy enough lol, ok if the rain lets up in the morning ill be on it first thing thanks speedy
Post by speedy1125 on Oct 2, 2011 19:10:46 GMT -5
Skip the part on that tire thread where he actually takes the tires off. Do this by an air compressor at a gas station, a friend who has an air compressor...whatever. Step one: remove the core to let the air out. Step two: using the clamp I showed, squeeze the tire together by the hole where the stem goes Step three: cut the old stem out Step four: remove the core from the new stem Step five: install new stem Step six: remove clamp Step seven: shoot air into the tire to set the bead Step eight: screw the core back in Step nine: inflate to 40 psi Step ten: drive on your way seems easy enough lol, ok if the rain lets up in the morning ill be on it first thing thanks speedy You dont have to lift it up in the air like that thread shows either just put it on the center stand. Raven just posted that thread to show you visually how you do this using a vice but using the clamp is the same thing. trust me if you can do the PDI like you have done, you can do this. that tire shop is just trying to make money off you. how much do they want to do this anyway?
Post by gy6luver on Oct 2, 2011 19:18:23 GMT -5
never got a quote
Post by speedy1125 on Oct 2, 2011 19:18:33 GMT -5
tools required for this valve stem job: access to air hose 10mm open end wrench core tool knife 6 or 8 inch ratcheting bar clamp:
Post by speedy1125 on Oct 2, 2011 19:23:31 GMT -5
here is the clamp at northern tool, $5 www.northerntool.com/shop/tools/product_523343_523343As I said, I have done this with no clamp at all but it is much easier with it because it holds the tire out of the way of the hole so you can use both your hands on the stem, one to hold the stem in, the other to put the rubber seal then retainer then the locking nuts. snug the first nut down but not gorilla tight, just good and snug so that the rubber compresses to make a good seal. then tighten the 2nd nut down on the first one good and tight so that it locks the first nut down. instructions: kurveygirl.com/shop/product_info.php?cPath=169&products_id=71
Post by gy6luver on Oct 2, 2011 19:24:13 GMT -5
6 or 8 inch ratcheting bar clamp: just saw one of those at mardens the other day
Post by 90GTVert on Oct 2, 2011 19:27:22 GMT -5
Post by speedy1125 on Oct 2, 2011 19:28:43 GMT -5
yay for videos!
Post by speedy1125 on Oct 2, 2011 19:34:06 GMT -5
yeah the soap spray bottle is a good idea you can clean your wheels while you look for bubbles
Post by ravensguildassasin on Oct 2, 2011 19:35:42 GMT -5
sadly it really is that easy. it seems more intimidating the first time doing it.
Post by gy6luver on Oct 2, 2011 20:58:12 GMT -5
OMG i love that, just ab it different with mine since they have nuts on them, love the END of the vid thanks brent and speedy
