Post by gooycheese on Sept 3, 2024 5:07:12 GMT -5
The temp gauge linked above is the one you would recommend?
Post by Zino on Sept 3, 2024 7:31:17 GMT -5
Post by gooycheese on Sept 8, 2024 16:59:03 GMT -5
Well working on temp gauge... 45mph is no problem now .. scooter is a lot more fun now. It does seem like more than 45 I will need to change some gears... Stock this thing is screaming... If going to gears what would be recommended?
Thank You.
Post by Zino on Sept 8, 2024 20:04:02 GMT -5
www.scootertuning.ca/en/101-gearsI used Athena 14/42 but any of these gears would add 5 mph or more You will have to reset the weights a notch lower when you get gears so you get the same shift points and the you keep spunky takeoff
