gutiwarrior
Malaguti F12 Project Wife
Post by gutiwarrior on Jul 9, 2020 21:02:51 GMT -5
back together and running! Sounds very very strong. STAY TUNED 😎
Sum-azn-kid
Post by Sum-azn-kid on Jul 10, 2020 2:34:17 GMT -5
Is your crank's wrist pin bearing a 10mm or did you upgrade to 12mm pin? That disk brake setup is clean BTW.
gutiwarrior
Post by gutiwarrior on Jul 10, 2020 18:29:58 GMT -5
Is your crank's wrist pin bearing a 10mm or did you upgrade to 12mm pin? That disk brake setup is clean BTW. Kept 10mm! Only going to get better on the brakes. Japan order coming in Wednesday. 200mm disk
gutiwarrior
Post by gutiwarrior on Jul 10, 2020 20:39:58 GMT -5
all but gains. Jog and vino real pulley. Smooth sailing!
Sum-azn-kid
Post by Sum-azn-kid on Jul 10, 2020 21:23:44 GMT -5
Where did u buy your crank? Everywhere I looked was out of stage6 10mm crank. Scooter tuning, swap shop and dyno scoot
gutiwarrior
Post by gutiwarrior on Jul 11, 2020 3:06:16 GMT -5
Where did u buy your crank? Everywhere I looked was out of stage6 10mm crank. Scooter tuning, swap shop and dyno scoot check scooter attack. If they don’t have it my buddy has a few he can sell and ship out.
Post by oldgeek on Jul 11, 2020 5:41:54 GMT -5
I just checked back in on this thread, WoW! Nice conversion on the front disc brake What a lousy stock front end they come with. I have the opportunity to buy my Vino back from the guy I sold it to cause he lost interest in scooters. I gotta say it is tempting.
gutiwarrior
Post by gutiwarrior on Jul 11, 2020 22:37:21 GMT -5
tuning. Tuning. And more tuning. Smoother out my shifting with the ncy pulley. Went with the lesser of the incline on the pulley. With porting and some upjeting I gained a good 4mph or so. Stronger pulls. The new front end is really getting tested! next will be reeds. I’ll install them tomorrow and upset again and start mapping out a tune again. Currently, 38/36 and in the middle for the pin.
Post by sevenninesandtens on Jul 15, 2020 16:40:37 GMT -5
got any tips for the dual throttle to single conversion?
I am slogging through that now and can't seem to get it right. Had the cable cut way too long so I trimmed it down and it is somehow still the same amount too long.
I dunno if I didn't cut the cable now. I thought I did but maybe not. Maybe just the housing.
How much of the cable did you have exposed into the throttle grip? I can't seem to get it right.
Post by Zino on Jul 15, 2020 17:42:31 GMT -5
I would be very interested in getting ahold of a couple of these reed cages for my vinos where did you come across them ?
gutiwarrior
Post by gutiwarrior on Jul 15, 2020 20:24:06 GMT -5
I used a cable off a zuma. Get rid of the other cable. Just use one notch on the vino throttle. Put a screw on the other hole as a stopper. That’s it.
gutiwarrior
Post by gutiwarrior on Jul 15, 2020 20:24:42 GMT -5
I would be very interested in getting ahold of a couple of these reed cages for my vinos where did you come across them ? Aliexpress. Reeds are nice. Intake way to big for the setup so just uses original.
gutiwarrior
Post by gutiwarrior on Jul 15, 2020 20:26:14 GMT -5
oem front disk wheel and 200mm disk/adapter finally came! And oem side kick stand it’s not bolted on but man. What an upgrade.
gutiwarrior
Post by gutiwarrior on Jul 15, 2020 20:35:17 GMT -5
Okay. So after playing around with different kits, porting, reeds, you name it,...this is a pretty fast vino. Gps 64 on flat road not tucked on a random day. I can have my buddy jump in there which is 30lbs lighter and he can make the speedo go around and touch the zero. 68-70 for sure. I am achieve that behind a car as well....that’s cheating though I want more power. MORE. SO. let’s play a game. Corsa. Meh. Would be a good upgrade. Needs some close attention to oil ratios and I still would be in the 70cc line. Getting to the same speed faster plus a few more. Mhr. Very nice as well. Still. Not the jump I want. I want to be able to feel scared. Like I will die. With a twist of my hand. That kind of jump..... These parts below are getting setup into the next engine going into this vino. It will be a jog 90, with a 54mmx45mm ported and mapped to its finest. Gears, bigger variator, stock wheel, 28mm carb, reeds, everything. THIS is the jump you all will be able to witness here. Over 100cc of wheelies and torque that will make you puke on a tiny vino. Special shout out to Frank at All Jog. Aka vino god. This all wouldn’t of been even thought of without him. I’d just slap a rc 1 and call it a day but what the quads are doing, our vinos will be doing. 😎 Subscribe and stay tuned....
Post by Zino on Jul 15, 2020 22:38:04 GMT -5
Wow 68 mph Show us Video I gotta see that How do you even keep 2 tires on the ground .
