Post by birdman on Jul 16, 2020 20:36:35 GMT -5
Frank is the man when it comes to 90 setups. I just read this whole thread thru and you said in the beginning "I want to keep this tame.". Now on your last post you said "I wana be scared when I twist the throttle." 😂 😂 😂 😂 I REALLY like where this is going!
gutiwarrior
Malaguti F12 Project Wife
Post by gutiwarrior on Jul 19, 2020 16:55:43 GMT -5
Frank is the man when it comes to 90 setups. I just read this whole thread thru and you said in the beginning "I want to keep this tame.". Now on your last post you said "I wana be scared when I twist the throttle." 😂 😂 😂 😂 I REALLY like where this is going! 😂😂😂 yea....
gutiwarrior
Post by gutiwarrior on Jul 19, 2020 17:06:47 GMT -5
Post by Zino on Jul 19, 2020 17:07:27 GMT -5
Guti you must have been a blast to party with .
It probably went something like this . Mom Dad I was just going to have a few friends over Listen to some Music .
Parents come home and find Guns and Roses on Stage in the Back Yard with Just a few thousand of Gutti's closest friends over .
Gutti doesn't do anything tame or lame .
gutiwarrior
Post by gutiwarrior on Jul 19, 2020 21:00:42 GMT -5
Guti you must have been a blast to party with . It probably went something like this . Mom Dad I was just going to have a few friends over Listen to some Music . Parents come home and find Guns and Roses on Stage in the Back Yard with Just a few thousand of Gutti's closest friends over . Gutti doesn't do anything tame or lame . Actually....when I was still home It did go something like that hahaha do it right or not at all. This will give my 150 a run for its money if not more. 😬
gutiwarrior
Post by gutiwarrior on Jul 19, 2020 21:17:41 GMT -5
70mph vino 70cc. Malossi sport Video stay tuned.
gutiwarrior
Post by gutiwarrior on Jul 19, 2020 21:43:23 GMT -5
Post by rehabkymco on Jul 19, 2020 22:24:23 GMT -5
Was just told about this vino on Friday. Congrats on 70. And with the 103cc oh boy she gonna be wild. We definitely have some FAST scoots here in Sussex County.
Post by Zino on Jul 20, 2020 7:57:52 GMT -5
That is awesome . Pulling away from cars on the Vino . You sure have a solid build can you post up what your build is right now so we all know what it takes to get the 70 mph video . Before you swap for 100 cc It was good to see your temp gauge also to show others that you can jet for real safe temps and still get plenty of power . You just leveled off at 300 degrees when you were on the throttle and you juiced the throttle a few times as you came off the throttle to keep from part throttle high temps . Alot of people seize up on deceleration . So its good to point out for the next guy.
gutiwarrior
Post by gutiwarrior on Jul 20, 2020 9:22:10 GMT -5
Definitely will get the whole list together! I’ve been trying to keep my signature up to date but it needs some tweaking. You mentioned Sussex county....where you at?! Before I remove the engine I’ll make sure to do a full walk around and detailed parts list. I MAY have the engine and whole setup for sale so you just have to bolt onto another vino.....pm anyone if interested!
It took a lot of work to get there and some help from some awesome people but with the right knowledge, it’s all possible. Before I did the gears it was a beast not wanting to be tamed. Wheelies every light. Beating my friends mopeds out of the line. I was told about this belt I’m running and after putting it, it maxed out the pulleys and variator. Wasn’t enough. Gears. Lighter rollers. Countless runs to make everything perfect! It’s a solid build and has no flaws.
Post by rehabkymco on Jul 20, 2020 9:30:40 GMT -5
Definitely will get the whole list together! I’ve been trying to keep my signature up to date but it needs some tweaking. You mentioned Sussex county....where you at?! Before I remove the engine I’ll make sure to do a full walk around and detailed parts list. I MAY have the engine and whole setup for sale so you just have to bolt onto another vino.....pm anyone if interested! It took a lot of work to get there and some help from some awesome people but with the right knowledge, it’s all possible. Before I did the gears it was a beast not wanting to be tamed. Wheelies every light. Beating my friends mopeds out of the line. I was told about this belt I’m running and after putting it, it maxed out the pulleys and variator. Wasn’t enough. Gears. Lighter rollers. Countless runs to make everything perfect! It’s a solid build and has no flaws. I live in Delmar and work in Rehoboth. Have a Kymco Agility that does upper 50s and a Baccio that's on the list at 56, but had gone 59 before the stock crank let go.
gutiwarrior
Post by gutiwarrior on Jul 20, 2020 9:37:51 GMT -5
Definitely will get the whole list together! I’ve been trying to keep my signature up to date but it needs some tweaking. You mentioned Sussex county....where you at?! Before I remove the engine I’ll make sure to do a full walk around and detailed parts list. I MAY have the engine and whole setup for sale so you just have to bolt onto another vino.....pm anyone if interested! It took a lot of work to get there and some help from some awesome people but with the right knowledge, it’s all possible. Before I did the gears it was a beast not wanting to be tamed. Wheelies every light. Beating my friends mopeds out of the line. I was told about this belt I’m running and after putting it, it maxed out the pulleys and variator. Wasn’t enough. Gears. Lighter rollers. Countless runs to make everything perfect! It’s a solid build and has no flaws. I live in Delmar and work in Rehoboth. Have a Kymco Agility that does upper 50s and a Baccio that's on the list at 56, but had gone 59 before the stock crank let go. right on. I’m always in rehoboth hanging out with Kristian at scooter city. We probably have met but no idea haha
Post by rehabkymco on Jul 20, 2020 11:22:39 GMT -5
I live in Delmar and work in Rehoboth. Have a Kymco Agility that does upper 50s and a Baccio that's on the list at 56, but had gone 59 before the stock crank let go. right on. I’m always in rehoboth hanging out with Kristian at scooter city. We probably have met but no idea haha Right, i was in there on Friday and he was telling about your Vino then. If you were to see a flat Black and orange Kymco that sounds like a 150cc then that's me.
Post by aeroxbud on Jul 20, 2020 14:32:56 GMT -5
Runs really strong. 😁
Post by Zino on Jul 20, 2020 16:59:36 GMT -5
You gotta put this build as a 70 up for vote on the speed list. 1 mile per cc is frickin amazing
