Post by 90GTVert on Nov 9, 2011 17:27:31 GMT -5
115 - 125 maybe.
Post by richiekunz on Nov 10, 2011 6:25:09 GMT -5
will it cause problem if I drill too big?
Post by 90GTVert on Nov 10, 2011 6:31:00 GMT -5
Too big or too small both cause problems. You can use solder to fill the hole and re-drill, but it's easier to work up step by step.
Post by richiekunz on Nov 10, 2011 6:37:29 GMT -5
So depend on size I should use 1.25mm ?
Post by 90GTVert on Nov 10, 2011 6:48:52 GMT -5
That would be a 125. I would start out with whatever you have or get that's the next size up from your current jet. Whichever bit is the smallest that doesn't fit through the jet, use that to start.
Post by richiekunz on Nov 10, 2011 7:46:28 GMT -5
Then What Should I do ?
Post by 90GTVert on Nov 10, 2011 8:35:03 GMT -5
Test ride. See how it performs. Look at the plug. Go up another step if it still doesn't seem right. If it starts getting worse, you've gone too far.
Post by richiekunz on Nov 10, 2011 8:57:22 GMT -5
Owh Yea ! The Plug ! I cant find where is my plug located...shame on me
Post by 90GTVert on Nov 10, 2011 9:10:51 GMT -5
Right side of the engine, near the front. This is a GY6 50, pretty much the same though. See the hole just behind the valve cover and the tip of the plug sticking out? You'll have a plug wire leading you right to it. A look with the shroud off.
Post by richiekunz on Nov 10, 2011 9:12:53 GMT -5
Post by 90GTVert on Nov 10, 2011 9:19:40 GMT -5
That and the appropriate cylinder head would turn it into a 150 instead of a 125. Should be good for improved performance all around, including more top speed. A long shot from 130km/h though. Maybe on the stock gauges, but accurately more like 100-105km/h I'd think. Check out the banners on the main page of the forum. You can find stock and upgrade parts for this engine there too. PFS even provides measurements of different bits so you can be sure it's right.
Post by richiekunz on Nov 10, 2011 9:25:19 GMT -5
Okay...But now standard cylinder head can reach 100kmh...without the air box lol
Post by 90GTVert on Nov 10, 2011 9:36:07 GMT -5
You just aren't going to see a 30% gain in top speed from going to 125 to 150. Maybe 10%? I dunno, I'm heavy so the average 150 does about 100km/h with me on it.
Post by richiekunz on Nov 10, 2011 9:40:17 GMT -5
Okay...Thanks a lot ! Gonna Continue Working on this Scoot !
Post by Goosey on Nov 12, 2011 12:29:19 GMT -5
The jet size I've seen most often on a 150cc setup with a uni filter is 120, so recommend you don't start with the 125. Try a google search, like, 125cc jet size, and you may get some forum hits that are relevent to what your doing?
