Post by richiekunz on Nov 19, 2011 19:31:52 GMT -5
Weight in the Variator ? do u mean the Roller Weight ?....Can I just cut off my Mufflers so It has bigger hole?
Post by rocketdog on Nov 19, 2011 20:58:35 GMT -5
Yes the roller weights. Yes you could but I would suggests one of Brents muffler mods before you go that far.
RD
Post by richiekunz on Nov 19, 2011 21:27:28 GMT -5
I accidentally Break the thing on A on the picture while taking off the nut to get through the Rollers....Should I find the original one or does it fit with other too and what the thing in A Called? that looks like a fan ?
Post by rocketdog on Nov 20, 2011 19:40:07 GMT -5
Ya lost me there Rich. Show me the picture of A.
RD
Post by richiekunz on Nov 21, 2011 3:27:55 GMT -5
Here is it Attachments:
Post by rocketdog on Nov 21, 2011 7:17:49 GMT -5
Post by richiekunz on Nov 21, 2011 8:26:32 GMT -5
Okay Thanks again for your information Rocketdog !
Post by richiekunz on Nov 24, 2011 6:38:12 GMT -5
Hey Guys ! I just changed my Roller Weight ! what I get is....My Engine Rev more then before....but the problem is its rev high but the speed kinda low than before....and my engine temperture raising faster....any idea?
Post by 90GTVert on Nov 24, 2011 9:42:59 GMT -5
The rollers are too light now. You could try mixing the new lighter weights with stock and see if that gets a better result. Stagger them in the variator... light/heavy/light/heavy/light/heavy
More RPM = More Heat
Post by stepthrutuner on Nov 24, 2011 10:07:08 GMT -5
Don't understand the rise in engine temp. Less load on engine (engine now turns faster relative to the rear wheel) and more cooling fan speed should mean cooler operating temps. For wheelies you need significantly lighter roller weights (close to one half the original one's weight probably) and stiffer clutch shoe springs that wont engage your clutch till around 4000 rpm. Top speed will be sacrificed but hill climbing will be much better. CVT tuning is a cut-and-try process requiring several ventures under the CVT cover. A worn or narrower drive belt will have much the same effect as lighter roller weights. Also adding length via thin washers the same inside and outside diameters as the hollow rod-like spacer the outer front pulley is fastened against and the inner one slides on (usually called the variator drive boss) will give quicker take off and a better chance of wheelieing.
All this is in the tech section under CVT Tuning.
Post by richiekunz on Nov 24, 2011 19:45:39 GMT -5
Post by 90GTVert on Nov 24, 2011 22:48:39 GMT -5
Ah, sliders. I've never tried, but I believe 2strokd mentioned at some point that you could mix rollers and sliders with decent results.
Post by richiekunz on Nov 24, 2011 23:40:55 GMT -5
So I should Try Mix them together ? I'm just worry if its gonna start a problem on something in my Pulley or what....
Post by richiekunz on Nov 26, 2011 8:40:41 GMT -5
Hello ?
Post by 90GTVert on Nov 26, 2011 9:45:49 GMT -5
I think they'd be fine. I guess the only real issue would be if the sliders opened the vari too far and the rollers could come out at max speed. I don't think that would happen with a stock vari, but I've never tried it.
