Post by 90GTVert on Aug 11, 2012 19:23:17 GMT -5
You'll have poor performance if it's too big or too small. Needs to be the right jet or within a small range of jets that will prob work alright to run well. Gotta be careful drilling jets because if the hole is no round at all it can make a big difference in how much flow there is.
Post by richiekunz on Aug 12, 2012 8:36:03 GMT -5
Okay I fixed it by replacing a new Jet lol.....
I would like to have bigger bore and piston.... btw if drill the bore bigger....without changing the piston, what will happen ? how if I cant find a suitable piston for my new bigger bore?
Post by 90GTVert on Aug 12, 2012 18:27:15 GMT -5
If you bore the cylinder and keep the same size piston it'll either never start or damage itself or both. Do not do that. You should be able to find big bore kits that would include what you need. Stock GY6 150 cylinder/piston would be larger than the 125.
Post by richiekunz on Aug 13, 2012 7:28:48 GMT -5
Okay...
Stage6 refer to what? what kind of scoot are label as stage 6 ?
Post by 90GTVert on Aug 13, 2012 13:07:44 GMT -5
Post by richiekunz on Sept 3, 2012 5:10:28 GMT -5
where does the camshaft located ?
Post by 90GTVert on Sept 3, 2012 16:46:08 GMT -5
Under the valve cover, on top of the cylinder head.
Post by richiekunz on Sept 30, 2012 23:39:00 GMT -5
Post by 90GTVert on Oct 1, 2012 20:43:48 GMT -5
I think 58.5mm is the largest that will bolt on without opening up the cases. PFS part number 169-314 is an example.
