Post by captincvmn on Jul 16, 2021 12:38:09 GMT -5
I shouldn’t have gone to look at T2’s 0-XX times. Now I know how slow I really am. I better look at some stock 4t times before I feel too sick.
shadees
Post by shadees on Aug 2, 2021 13:27:15 GMT -5
Hey ho my fellow Keeway tuner I just bought a Tachometer,, but cant remember what wire to connect it to :/ I remember the original display had a RPM.. But after I modified my wirering I forgot to take notice in that.. I hope you can help Im using the D connection method.. - Frederik
Post by geoffh on Aug 2, 2021 15:48:26 GMT -5
Wow that's complicated,I had a battery powered tacho you just wrapped the "sensor wire" around the ignition coil wire and it got there,I "think" you need power and earth and wrap the sensor around the coil wire,best to have a child or spouse hold it all while you take notes Geoff
Post by captincvmn on Aug 2, 2021 15:52:00 GMT -5
Hey ho my fellow Keeway tuner I just bought a Tachometer,, but cant remember what wire to connect it to :/ I remember the original display had a RPM.. But after I modified my wirering I forgot to take notice in that.. I hope you can help Im using the D connection method.. - Frederik I’ll look tonight. I didn’t make a picture of my notes for what color went where.
Post by captincvmn on Aug 2, 2021 16:47:33 GMT -5
I have my bearing stand, now I have wheel weights. Maybe in a week or two I’ll have smooth riding?
Post by captincvmn on Aug 2, 2021 19:28:55 GMT -5
Hey ho my fellow Keeway tuner I just bought a Tachometer,, but cant remember what wire to connect it to :/ I remember the original display had a RPM.. But after I modified my wirering I forgot to take notice in that.. I hope you can help Im using the D connection method.. - Frederik I found my notes from last time and I did not write down the tach wire. However, there was only wire from the plug not being used and that’s the grey wire. I believe the grey wire was the tach input.
shadees
Post by shadees on Aug 3, 2021 3:04:20 GMT -5
I found my notes from last time and I did not write down the tach wire. However, there was only wire from the plug not being used and that’s the grey wire. I believe the grey wire was the tach input. Thx alot man In my notes I had written the grey wire to be the fuel gauge.. But will do some testings later today when I get my new cylinderkit installed.. - Frederik
Post by captincvmn on Aug 6, 2021 17:34:21 GMT -5
Post by captincvmn on Aug 7, 2021 15:23:45 GMT -5
Mechanical advantages can be advantageous.
Post by captincvmn on Aug 8, 2021 14:17:26 GMT -5
Post by captincvmn on Aug 8, 2021 15:34:33 GMT -5
Post by 90GTVert on Aug 8, 2021 17:11:29 GMT -5
There are covers that are better for big ass pulleys. Some have more room stock and don't need much work. These days, covers are harder to find at a reasonable price than I ever recall though. The ATV covers are one that are often larger, but they may also be deeper. Deeper means the shaft won't go into the cover bearing as much.
Post by aeroxbud on Aug 8, 2021 17:22:32 GMT -5
That's a lot of work. Hopefully the wheelies will be worth it. What bike did you get the torque drive from?
Post by captincvmn on Aug 8, 2021 17:49:45 GMT -5
It is a lot of work but I knew going in it would be. The pulley came from Mr. Ott. I can’t leave the reply to check messages but I believe he said a Piaggio?
Post by captincvmn on Aug 8, 2021 19:28:02 GMT -5
Had my first walk of shame with the new belt setup. I knew it was going to happen though. I had the pulley “darn close” so I figured I’d let it self clearance the remaining bit. I made it 1/4 mile and the TD got hung up on the case and stalled forward progress. I shut it off and walked back.
