pewpew
Post by pewpew on Jun 13, 2021 19:18:51 GMT -5
Im having 2 problems with the scoot, 1 is that all of the kickstarter parts keep breaking, the gears crack and fall apart with the first few kicks, i dont know what can cause that except too much compression? And also the rollers keep flattening, i have tried 5,5 and 5 gram rollers and both got flat in 100 kilometers, should i use grease on them to help them roll?
Post by captincvmn on Jun 13, 2021 21:23:18 GMT -5
Could the rollers possibly be the wrong size? Diameter?
pewpew
Post by pewpew on Jun 14, 2021 12:27:21 GMT -5
Could the rollers possibly be the wrong size? Diameter? No, they are 19x15,5
pewpew
Post by pewpew on Jul 11, 2021 20:47:22 GMT -5
Never seen this before, almost a brand new variator and the variator bushing is cracked. Also alot of wear in the guide posts
Post by captincvmn on Jul 11, 2021 21:15:59 GMT -5
Almost?
pewpew
Post by pewpew on Jul 12, 2021 9:29:29 GMT -5
Post by captincvmn on Jul 12, 2021 11:13:48 GMT -5
That’s not many miles. Brass looks old.
pewpew
Post by pewpew on Jul 12, 2021 18:39:05 GMT -5
Post by 808ministroke on Jul 16, 2021 2:55:18 GMT -5
While man your builders coming along amazing using killer job app perhaps to have more power than or power then Thor's hammer. Anyway The easy boost subframe what models did you have to what models did you have to end up doing again so I can know can know what I'll be in for or even if I want or even if I want to go down that route. I really wanna hear a sound clip or a Sia rev is the red video of this bike badly....🤘🛠💣💥
pewpew
Post by pewpew on Jul 16, 2021 3:13:35 GMT -5
Post by aeroxbud on Jul 16, 2021 6:06:16 GMT -5
You might be able to get a replacement bush for the variator. You can press them out. That bit on the torque spring is just a seat for the spring.
Post by 90GTVert on Jul 16, 2021 7:07:50 GMT -5
pewpew
Post by pewpew on Aug 1, 2021 22:45:37 GMT -5
pewpew
Post by pewpew on Aug 2, 2021 11:20:04 GMT -5
Bought a new exhaust for it and sold the mxs, doesnt fit even close
Post by captincvmn on Aug 2, 2021 11:25:57 GMT -5
It’s kinda close? The fender is way too far from the tire. Looks like it’s laying on it. Is the pipe made for that cylinder like is the seat angled or straight?
