Post by captincvmn on Aug 17, 2021 18:47:29 GMT -5
Ouch!
pewpew
Post by pewpew on Aug 19, 2021 9:44:17 GMT -5
Just placed an order for the 2fast crank and cylinder kit, should be here next week. Is there a way to change the topic name?
Post by captincvmn on Aug 19, 2021 11:33:38 GMT -5
Just placed an order for the 2fast crank and cylinder kit, should be here next week. Is there a way to change the topic name? 90GTVert
Post by aeroxbud on Aug 19, 2021 12:46:54 GMT -5
Just placed an order for the 2fast crank and cylinder kit, should be here next week. Is there a way to change the topic name? You mean the title? If you go to the first post you made in the thread. It will let you edit the title.
pewpew
Post by pewpew on Aug 19, 2021 12:56:45 GMT -5
Just placed an order for the 2fast crank and cylinder kit, should be here next week. Is there a way to change the topic name? You mean the title? If you go to the first post you made in the thread. It will let you edit the title. Thanks
Post by aeroxbud on Aug 19, 2021 13:54:54 GMT -5
Could we see a new faster submission in the scooter speed list soon? 🤔
pewpew
Post by pewpew on Aug 23, 2021 7:34:01 GMT -5
Got the crank
pewpew
Post by pewpew on Aug 29, 2021 11:49:52 GMT -5
Post by aeroxbud on Aug 29, 2021 13:15:31 GMT -5
What didn't impress you about it?
pewpew
Post by pewpew on Aug 29, 2021 13:29:48 GMT -5
What didn't impress you about it? The transfer dividers look like someone has ruined them with a dremel and the exhaust port isnt 100% symmetrical
Post by aeroxbud on Aug 29, 2021 13:41:40 GMT -5
That's not good. I can understand you don't expect to be sorting out problems on a kit like this.
pewpew
Post by pewpew on Sept 3, 2021 19:36:54 GMT -5
The 100cc stage6 just launched and i would like to buy it, if someone buys the 2fast on monday i will order the kit and malossi cases. I was just wondering like what parts fit the stage6 crank and malossi cases? What ignition and is it all piaggio parts?
Post by aeroxbud on Sept 4, 2021 4:33:30 GMT -5
Are you on about the RC one cases? They have Minarelli, or piaggio cases. You would need to order the Minarelli stuff. It's designed to run MHR race ignition.
Post by 90GTVert on Sept 4, 2021 6:14:41 GMT -5
The RC-One cases are all basically a Piaggio design or based on that. They just change the mounts to make it fit where an actual Minarelli or Piaggio engine once went. To my knowledge, if you want bolt-on simplicity, the only ignition that fits the RC-One is the Malossi ignition for it. Piaggio or Minarelli ignitions don't fit. Some have adapted them, but it may require a custom mounting plate and machining the rotor. There was an MVT sold for it by ScooterTuning, but naturally it went extinct when I ordered it and I was told that it probably won't be available. I've got a Piaggio ignition, but haven't so much as opened a box for my RC-One to tell you what really needs to be done to make it work.
pewpew
Post by pewpew on Sept 4, 2021 11:07:37 GMT -5
The RC-One cases are all basically a Piaggio design or based on that. They just change the mounts to make it fit where an actual Minarelli or Piaggio engine once went. To my knowledge, if you want bolt-on simplicity, the only ignition that fits the RC-One is the Malossi ignition for it. Piaggio or Minarelli ignitions don't fit. Some have adapted them, but it may require a custom mounting plate and machining the rotor. There was an MVT sold for it by ScooterTuning, but naturally it went extinct when I ordered it and I was told that it probably won't be available. I've got a Piaggio ignition, but haven't so much as opened a box for my RC-One to tell you what really needs to be done to make it work. Yeah i researched them all night, my best bet is the 2fast passion cases and 2fast 47/100mm crankshaft. I can either order the stage6 100cc if it comes on sale seperately or just buy an 2fast 100cc fl. 2fast cases are weird since they are all minarelli but the ignition mount looks the same as rc one. The crank is minarelli so minarelli parts fit but i would have to make an adapter plate for the stator
