Post by speedy1125 on Oct 29, 2011 23:12:21 GMT -5
So its running now i take it
Post by abansb on Oct 30, 2011 0:14:02 GMT -5
here is what I did rechecked the valves and timing is showing in time with the T not the line it is idling now but wont pull till I lift the back end off the ground then it wants to rev up this makes no sense at all I thought maybe the exhaust was stopped up and took it loose from the engine and it does the same
anyone have any suggestions at what else could be wrong
Thanks Tom
Post by abansb on Oct 30, 2011 0:15:37 GMT -5
not yet Stroker this thing has me stumped
Post by 90GTVert on Oct 30, 2011 6:40:54 GMT -5
I'd try to time it with the line first and see if that made any improvement.
If not, I'd clean the carb and check over the CVT thoroughly. Also, install the airbox if it's not already on.
Post by abansb on Oct 30, 2011 12:50:30 GMT -5
ok I took the belt back off and it idles and revs up so does that mean that something is wrong with the CVT
Post by abansb on Oct 30, 2011 13:29:48 GMT -5
when checking the CVT I know nothing I have been going by the PDF's I have got from here
Post by speedy1125 on Oct 30, 2011 13:42:41 GMT -5
sounds like your rollers might be all out of whack
Post by abansb on Oct 30, 2011 16:08:18 GMT -5
I have 2 more engines to use parts from I will take it apart and check the rollers
Post by speedy1125 on Oct 30, 2011 16:10:41 GMT -5
rollers are in the variator ..inside the cvt cover, front pulley. not inside the crankcase
if you ran it with no belt on it the rollers are out of place.
Post by abansb on Oct 30, 2011 16:24:03 GMT -5
oh sorry so they are out of place b/c I ran it with no belt ?
Post by speedy1125 on Oct 30, 2011 16:30:57 GMT -5
oh sorry so they are out of place b/c I ran it with no belt ? did you run it with the belt off and the variator on? then yes
Post by abansb on Oct 30, 2011 16:32:45 GMT -5
Thank you Stroker
Post by abansb on Oct 30, 2011 19:14:50 GMT -5
well I can not get it off don't have away to keep it from turning I guess I will have to wait to get something to take it off
Post by speedy1125 on Oct 30, 2011 19:23:42 GMT -5
well I can not get it off don't have away to keep it from turning I guess I will have to wait to get something to take it off i have an air compressor but many here use the electric impact guns from harbor freight or northern tools for the variator nut.
Post by abansb on Oct 30, 2011 20:55:41 GMT -5
yea I don't have any of those things here just now starting to get me a few tools built up
