Post by abansb on Oct 31, 2011 6:44:29 GMT -5
I will be trying to do this today sometime I will post back to let you guys know what happens
again thanks guys for all the help
Post by speedy1125 on Oct 31, 2011 11:00:02 GMT -5
;D
Post by abansb on Nov 2, 2011 12:14:49 GMT -5
OK I finally got the nut of had to use a small wrench inside the CVT wedged it in between the teeth got it back on the belt on
Now I am not getting any fire at all I just got the coil a month ago
It was running fine 2 days ago
this thing is so aggravating I said I was going to put it on craigslist but I love it to much to do that lol
Post by speedy1125 on Nov 3, 2011 3:43:19 GMT -5
Post by abansb on Nov 3, 2011 10:09:20 GMT -5
yes they where out of place I checked all the wiring and kill switch I think I have another CDI box I will change it and see what happens
Post by abansb on Nov 3, 2011 16:03:25 GMT -5
Post by abansb on Nov 3, 2011 16:27:57 GMT -5
I also tried another CDI from a friends Scooter and still no spark I guess the coil is fried
Post by 90GTVert on Nov 3, 2011 18:23:55 GMT -5
You've eliminated the CDI and the kill circuit, but there's more than just the coil left. It could be the coil or the stator still. Below are links to an article and a manual that have info and specs about testing both. Troubleshooting GuideService Manual
Post by abansb on Nov 3, 2011 18:54:21 GMT -5
thanks 90GTVert will check those and see
Post by abansb on Nov 3, 2011 19:26:12 GMT -5
I just tested the coil the primary coil is 0.00 and secondary with and without cap is also 0.00 and as I was checking these started to rain on me so checking the stator will have to wait
Post by speedy1125 on Nov 3, 2011 19:31:27 GMT -5
I just tested the coil the primary coil is 0.00 and secondary with and without cap is also 0.00 and as I was checking these started to rain on me so checking the stator will have to wait on the ohms scale are you getting 'OL' for 'open loop' or are you getting a reading of 0.00 of resistance? something doesnt add up there. remember you are checking for continuity not voltage, so you must set your meter to the ohms scale.
Post by abansb on Nov 3, 2011 19:33:08 GMT -5
I got it set to 20k and no I am not getting OL I am getting a reading of 0.00
It is set to ohms
Post by abansb on Nov 3, 2011 19:47:05 GMT -5
also right before I posted about the coil after checking the CDI I ordered a new coil from Enviromoto's
I hope it is not something else if so I guess I will have an extra coil lol
Post by abansb on Nov 3, 2011 20:05:05 GMT -5
well I ordered one from Enviromoto's for 14.85
Post by speedy1125 on Nov 3, 2011 20:09:18 GMT -5
one i have laying here reads 1.4k as long as the coil is not open then its most likely not the coil. coils rarely go bad. do you have power to the cdi?
