Post by buddy50li on Apr 24, 2021 23:07:46 GMT -5
What happened to the OEM headlight assy?
Post by jkeney on Apr 24, 2021 23:36:51 GMT -5
What happened to the OEM headlight assy? I did a naked bar setup with a trailtech vapor, and a stage 6 fuel meter. Mounted the led pod on the nose cones front bolt. Didnt drill any holes except a toggle for the light in the leg sheild.
Post by jkeney on Apr 26, 2021 19:30:21 GMT -5
Tagged and titled! I rode around and used up a whole tank of gas. Ran to the gas station once I got back and grabbed oil, mixing bottle, and gas can. I swear it cut off as I was pulling into the station. Lol. Top speed recorded was 63mph at 10600 rpms. Top temp recorded was 350 f on the nose. Cruising temps are between 290 and 310 f. Changed clutch springs from malossi white to malossi yellows. Changed from 5.5 to 6.5 gram weights.
Post by Zino on Apr 26, 2021 19:42:57 GMT -5
Nice work Sounds like you got a solid tune and High performing Beast. 60 plus mph is a big achievement.
Post by jkeney on Apr 26, 2021 23:07:07 GMT -5
Nice work Sounds like you got a solid tune and High performing Beast. 60 plus mph is a big achievement. I had so much fun today!
Post by lunatuck on Apr 27, 2021 11:14:28 GMT -5
Awesome! Gonna be a fun summer!
Post by lunatuck on Apr 28, 2021 9:19:45 GMT -5
Did you have to press 2 gears for the gear up kit? Or just one?
Post by jkeney on Apr 29, 2021 9:24:57 GMT -5
Did you have to press 2 gears for the gear up kit? Or just one? I had to press on off of the axle and the secondary had to be pressed off and small on pressed in its place.
Post by lunatuck on Apr 29, 2021 9:38:45 GMT -5
Did you have to press 2 gears for the gear up kit? Or just one? I had to press on off of the axle and the secondary had to be pressed off and small on pressed in its place. Thanks. Now it all makes sense. I found a motorcycle shop to press the gears, but they seemed clueless about the process and I know the Buddy is different then the Zuma and GY6, which is what most videos show.
Post by jkeney on Apr 29, 2021 21:34:04 GMT -5
Post by repherence2 on Apr 30, 2021 16:25:06 GMT -5
^ Nice work! Thank you for documenting and sharing. You are like the Genuine Buddy 50 pioneer on this forum. I admire your perseverance.
Now i have someone to follow as a guide if i ever end up buying a Buddy50.
Im happy for you! Have fun 2-strokin' and remember to ride safe.
Post by hippo008 on Apr 30, 2021 16:44:30 GMT -5
I am very interested in that LED light. Whats the deal with it? Model number? I need another light for my Roughhouse and I'm not sure what to use.
Post by genwine on Jun 8, 2021 20:12:16 GMT -5
Very nice scooter. Would you mind listing and/or providing links to all the parts of your naked handlebar setup? Thanks in advance.
Post by jkeney on Jun 14, 2021 12:22:12 GMT -5
Post by lunatuck on Jun 14, 2021 12:50:05 GMT -5
Whoa. There is an engine for sale on ebay for a very good price. Hint hint. Ugh. It may have sold. Was $199 free shipping.
