Post by chadbullet on Jun 14, 2021 12:56:52 GMT -5
that is impressive damage!
Post by jkeney on Jun 14, 2021 13:37:46 GMT -5
Whoa. There is an engine for sale on ebay for a very good price. Hint hint. Ugh. It may have sold. Was $199 free shipping. Yeah im definitely in the market for a new motor...
Post by jkeney on Jun 14, 2021 13:38:31 GMT -5
that is impressive damage! Made it count didnt we?
Post by 190mech on Jun 14, 2021 17:14:47 GMT -5
That one needs to go in the glass show case at a 2stroke museum..Hope you will tear it down and look for possible failure points...
Post by Zino on Jun 14, 2021 19:24:20 GMT -5
Wow That blew up to close to your family jewels.
Sum-azn-kid
Post by Sum-azn-kid on Jun 15, 2021 23:58:13 GMT -5
Dang that sucks.... Stock crank I'm guessing?
Post by Zino on Jun 16, 2021 7:19:28 GMT -5
Jkenney can you measure the malossi variator diameter for the Buddy . And verify the the stock diameter for the stock variator and drive face . If you have a way to measure ramp angles If you could take pictures with them side by side it would be very helpful.
I am trying to up size belts .
Post by lunatuck on Jun 16, 2021 10:00:36 GMT -5
I’ll be the start was a crack at the top of the conrod. Then it just preceeded to mutilate anything in its path.
Post by jkeney on Jun 16, 2021 11:36:09 GMT -5
Dang that sucks.... Stock crank I'm guessing? Yeah, im really kicking myself in the ass for not just getting the athena or TP crank. Lord knows i spent enough money to justify spending that much more.
Post by jkeney on Jun 16, 2021 11:39:22 GMT -5
I’ll be the start was a crack at the top of the conrod. Then it just preceeded to mutilate anything in its path. That would be what I am observing from the carnage. It looks like there was a hairline crack in the conrod before it shit the bed. The conrod fragment still on the piston has tell tale signs of oxidation in the crack. The outer areas or the crack are darker than the fresh snapped center piece.
Post by 190mech on Jun 16, 2021 17:26:54 GMT -5
Thanks for the investigation report!!
Post by hippo008 on Jun 17, 2021 8:33:03 GMT -5
I’ll be the start was a crack at the top of the conrod. Then it just preceeded to mutilate anything in its path. That would be what I am observing from the carnage. It looks like there was a hairline crack in the conrod before it shit the bed. The conrod fragment still on the piston has tell tale signs of oxidation in the crack. The outer areas or the crack are darker than the fresh snapped center piece. I have been using the Jasil full circle race crank for PGO and it's great. Higher primary compression and it's rated to 14,000RPM. I don't know what kind of RPM you're pushing but it could be worth the upgrade
Post by jkeney on Jun 17, 2021 15:50:34 GMT -5
That would be what I am observing from the carnage. It looks like there was a hairline crack in the conrod before it shit the bed. The conrod fragment still on the piston has tell tale signs of oxidation in the crack. The outer areas or the crack are darker than the fresh snapped center piece. I have been using the Jasil full circle race crank for PGO and it's great. Higher primary compression and it's rated to 14,000RPM. I don't know what kind of RPM you're pushing but it could be worth the upgrade When i can get ahold of a new motor, it will be getting an upgraded crank for the next build
Post by hippo008 on Jun 17, 2021 17:25:47 GMT -5
I bet I can source a used buddy motor locally, you'd have to pay to have it shipped, want me to put out that I need a running buddy motor? I have a lot of local connections through my scooter club.
Post by jkeney on Jun 17, 2021 21:58:59 GMT -5
I bet I can source a used buddy motor locally, you'd have to pay to have it shipped, want me to put out that I need a running buddy motor? I have a lot of local connections through my scooter club. Yes that would be great. I myself live in northern va.
