Post by sToRm on Jun 27, 2021 7:43:03 GMT -5
How is your project going? I'm in Greensboro if you want to ride or pick my brain. Also, I have loads of parts lying around that you might be able to use.
Post by bringtheruckus on Jul 24, 2021 20:13:20 GMT -5
Update, CVT stuff.. I got the NCY Variator kit from Rolling wrench and had it installed. I got the five gram weights with it and I lost much top end speed. Any suggestions, guys?
Post by Zino on Jul 24, 2021 21:33:56 GMT -5
You might not be getting full belt travel with weights that light .
Try 1/2 and 1/2 5 gram weights and your stock weights to test .
Just run 5/7/5/7/5/7 to keep balance and see if that makes a difference .
Post by woodini on Jul 25, 2021 0:01:41 GMT -5
How much do you weigh?
Post by bringtheruckus on Jul 25, 2021 12:49:00 GMT -5
I am about 165 lbs. I have also lightened the Ruckus a bit. I got the lithium battery and the Yoshi pipe which was about a 7 lb drop for the two. Then I got the extra low seat frame and drag bars, Having less material, that should have dropped a couple more pounds. It had to be at least ten pound total drop.
Post by woodini on Jul 26, 2021 0:47:00 GMT -5
Being so light ya might wanna try some heavier weights. I’m 175 and gonna try 5.5 next
Post by bringtheruckus on Dec 2, 2021 21:08:28 GMT -5
I still have not gotten the signals right.
