Post by bringtheruckus on May 29, 2021 14:23:06 GMT -5
Maybe someone can tell me why the right four or so red LED lights in the tail light will not come on?
Post by woodini on May 29, 2021 15:07:43 GMT -5
Maybe they’re bunk?
Post by sToRm on May 29, 2021 16:03:58 GMT -5
What kind/brand tail light are you using?
Post by Happypancake! on May 29, 2021 18:38:39 GMT -5
Running led blinkers and mnntbx turtle brake light I had to add a resistor
Post by bringtheruckus on May 29, 2021 23:05:25 GMT -5
It came from Rolling Wrench, but looks exactly like the one from TRS.
Post by jbjhillbilly on May 31, 2021 2:40:25 GMT -5
It came from Rolling Wrench, but looks exactly like the one from TRS. Give them a call. From everything I’ve heard, they’re pretty decent with customer service.
Post by fuzzyruttin on May 31, 2021 10:11:37 GMT -5
It came from Rolling Wrench, but looks exactly like the one from TRS. Give them a call. From everything I’ve heard, they’re pretty decent with customer service. Agree. I bought my GY6 kit from them, among other things. Responsive and helpful when I had questions.
Post by bringtheruckus on May 31, 2021 18:40:28 GMT -5
I emailed them Saturday night, but today is a holiday. Hopefully, tomorrow I will know something. SO, would I have had better luck with a different flasher relay?
Post by aeroxbud on Jun 1, 2021 5:07:09 GMT -5
You can buy a relay that will work with led lights. Some even work with both kinds. Saves having to fit resistors inline. You will still probably have to add resistors to the light. Is it a read light with turn signal built in?
Post by bringtheruckus on Jun 1, 2021 20:59:24 GMT -5
Yes, it is.
Post by bringtheruckus on Jun 1, 2021 21:01:23 GMT -5
I got the right stem in and put the drag bars on that have the aluminum plate that holds the stock speedometer. I am having so much trouble with the brake lines. They want to be exactly where the speedometer is at and this is affecting the steering.
Post by woodini on Jun 1, 2021 22:01:52 GMT -5
Post by bringtheruckus on Jun 1, 2021 22:05:25 GMT -5
Also, is there a shorter rear shock to lower a Ruckus that is not stretched?
Post by sToRm on Jun 1, 2021 22:30:06 GMT -5
NCY makes good ones, not sure if they work for non stretched Rucks. The rear wheel might not have enough clearance.
Post by bringtheruckus on Jun 4, 2021 18:18:31 GMT -5
I just tried the blinker relay that one of you suggested and no change. I am going to order the in line resistors, now.
