Post by Scootrific on Apr 28, 2023 13:13:42 GMT -5
Why are you wanting to remove the oil injection? Is it giving you problems. I would personally never remove one on a daily driver just for the convenience it gives you. On a race bike or similar I understand but I’ve ran them on 2 70 zumas & a vino 70 for thousands of miles with no issues. Just use good oil. No, but I have a bigger carb and I want to use the oil tank as a second fuel tank, So I have more range.
Post by aeroxbud on Apr 28, 2023 14:54:47 GMT -5
Not sure how the Aprilia oil pump is set up. But usually you can just remove the drive wheel to the pump. This leaves the pump in place, but none operational.
Post by Scootrific on Apr 29, 2023 4:51:47 GMT -5
Not sure how the Aprilia oil pump is set up. But usually you can just remove the drive wheel to the pump. This leaves the pump in place, but none operational. When I swapped all the intake parts and also the 17,5mm carb to Malossi 21mm PHBG one, I did peek under the oil pump cover, and did try to get some more oil flow out of the pump. I have not done this before, so I failed. Under the 2020 Aprilia SX 50 Factory oil pump cover, looks like this:
Post by Scootrific on Apr 29, 2023 5:00:49 GMT -5
Today I did ordered some parts from Scooter-Attack (Germany) - TOTAL 112,40 € incl. shipping: 1 × Screw Set rear sprocket M7x25mm Tomos A35 1 × Front Sprocket Derbi Euro 3 12 teeth 1 × Rear Sprocket 52 teeth - 420 AFAM Aprilia SX 50 1 × Reinforced Chain 132 links size=420 1 × Chain Master Link AFAM 420 gold 1 × Sticker Sheet Aprilia Racing 25x20cm (Gonna buy the fairing kit later - Black) 1 × Oil Pump Cover KRM black AM6 / Derbi 1 × Clutch Cable Derbi Euro 3 / Euro 4 (just in case) 1 × Cable Adjuster Screw M6x1.00 - L.18mm - sleeve D.6mm 1 × Throttle Cable Kit universal 1.2mm x 2 meters Motoforce Racing red
Post by Lucass2T on Apr 29, 2023 6:07:06 GMT -5
Not sure how the Aprilia oil pump is set up. But usually you can just remove the drive wheel to the pump. This leaves the pump in place, but none operational. When I swapped all the intake parts and also the 17,5mm carb to Malossi 21mm PHBG one, I did peek under the oil pump cover, and did try to get some more oil flow out of the pump. I have not done this before, so I failed. Under the 2020 Aprilia SX 50 Factory oil pump cover, looks like this: Why did you want to get more flow from it? Was it running lean? Id rather leave the pump alone apart from maybe checking if the marks still line up and maybe bleeding it. More oil isn't necessarily better. Changing to a 100% synth oil Like Motul 710 might be a better, easier option here.
Post by Scootrific on Apr 29, 2023 15:26:54 GMT -5
Why did you want to get more flow from it? Was it running lean? Id rather leave the pump alone apart from maybe checking if the marks still line up and maybe bleeding it. More oil isn't necessarily better. Changing to a 100% synth oil Like Motul 710 might be a better, easier option here. I will check it. Today the exhaust got little bit louder. Also, while I was riding, there was some vibration coming and also the bike is making an tin can noise too now. That was not there, after the intake and carb swap. I need to check those out soon. Maybe the reed valve screws got loose or something. I need to change and test other main jets and swap the bottom cover of the carb anyway. Then I take the intake off and check the reed valves and if they are loose, I will put some thread-lock there. Green one is ok or should I use some other color?
Post by Scootrific on Apr 29, 2023 15:30:52 GMT -5
Post by Lucass2T on Apr 29, 2023 17:07:11 GMT -5
Why did you want to get more flow from it? Was it running lean? Id rather leave the pump alone apart from maybe checking if the marks still line up and maybe bleeding it. More oil isn't necessarily better. Changing to a 100% synth oil Like Motul 710 might be a better, easier option here. I will check it. Today the exhaust got little bit louder. Also, while I was riding, there was some vibration coming and also the bike is making an tin can noise too now. That was not there, after the intake and carb swap. I need to check those out soon. Maybe the reed valve screws got loose or something. I need to change and test other main jets and swap the bottom cover of the carb anyway. Then I take the intake off and check the reed valves and if they are loose, I will put some thread-lock there. Green one is ok or should I use some other color? Always use blue. All parts that have a gasket between them don't really need thread locker. The gasket's natural compressing out makes the screws stay tight. You could use a little drop on the reed screws tho. I think I have mine thread locked too with Loctite 242. Tin can sound all of a sudden is as far as I can see only possible if the pipe was restricted and it unrestricted itself. Otherwise it doesn't make any sense. By the way, 2t's should make a tin can sound! It's awesome!
Post by aeroxbud on Apr 29, 2023 18:30:43 GMT -5
Post by bigmatthew86 on Apr 29, 2023 18:38:30 GMT -5
As long as he’s jetted right. Otherwise that can be a bad thing.
Post by Scootrific on Apr 30, 2023 2:23:39 GMT -5
As long as he’s jetted right. Otherwise that can be a bad thing. Main Jet 95 right now
Post by Scootrific on Apr 30, 2023 4:36:35 GMT -5
Making the luggage rack video. from Flux-Core welder to welding with gas (argon-co2 mix) And having a work/welding table. Atlast The table makes my work easier now. Now I just have to make the case mounts for both sides and paint the rack. Or I just mount the case on top. Not decided jet. Also, I have to make a spark plug tool for my Aprilia SX50 too, because the one I have, do not fit because the tight tolerance between sparkplug and fuel tank. I will make it from 21mm car sparkplug tool soon
Post by aeroxbud on Apr 30, 2023 5:44:33 GMT -5
Post by Scootrific on Apr 30, 2023 11:20:56 GMT -5
"Why buy it, when you can make it!" I have two car spark plug tools, what are 21mm, so I will make it from that and also I will sacrifice one of the wrenches to do it.
Post by Scootrific on May 3, 2023 10:35:54 GMT -5
Yesterday, I went to massage and decided to go with my bike. It was cold outside and my bike died 2 times on idle. Looks like I need to try out the old BR8 spark plug instead of the Denso BR9 series one, or rise the rpm´s
