Post by ryan_ott on Dec 9, 2021 8:58:09 GMT -5
I usually set seals just below the tapered edge as you have it. Should be fine.
Post by pete130 on Dec 9, 2021 18:16:40 GMT -5
Yes i was thinking and hopeing the same . Well found out my digtal vermers calapers were not reading right, so got new today and need to recheck squish lucky I always keep solder I squashed, I realy hope its right and they stopped working right after I did can only hope , so shows you don't cheack once do it 3 times lol
Post by pete130 on Dec 9, 2021 23:17:03 GMT -5
Well I was lucky when I did my squish,the digital calapers i used were working at the time,after I did it they were reading way out, so new set today and im ok .56 says .55 but im happy, I did use sealent on base gasket shouldnt need being brand new, my 6000kg press wasn't strong enough to press gears, so there at shop now getting done, I made up some blocking plates fto do pressher test, so waiting for that to dry and gears to be ready and back into it ,last pic is of 2 orings the black one fits head perfectly but for the life of me I can't find were green one goes any ideas there's noting I can find that it would fit into, unless its for the ignition but for what its malossi team2 rotor set up no lights, ill be running lithium rechargeable batteries
Post by ryan_ott on Dec 10, 2021 12:00:50 GMT -5
That gasket set covers the 70cc version also so don’t be alarmed if you can’t find a home for everything in the set.
Post by pete130 on Dec 11, 2021 0:44:38 GMT -5
Well went to the trouble to do leak down test, lucky I did as again with malossi, massive leak at base gasket , and just to let you know molissi think a full motor is with parts missing full motor can't not be started with parts they send, so don't belive anything till u see it
Post by aeroxbud on Dec 11, 2021 2:51:02 GMT -5
Yes pitobread found some small parts had to be purchased to get the RC one usable.
Post by ryan_ott on Dec 11, 2021 13:27:28 GMT -5
You can see my Zuma thread for everything I found that needed to be tended to.. metal chips everywhere, mismatched ports.. It does run well once together but a lot of quality control issues I haven’t seen with other manufacturers.
Post by pete130 on Dec 11, 2021 17:51:45 GMT -5
Post by pete130 on Dec 11, 2021 17:53:34 GMT -5
Thanks for the info, was a bit disjointed yesterday,but today is a new one, im glad its not just me that got a bad kit, and its all about making it work right, just didn't expect a few things thanks again ill have a look at your post
Post by pete130 on Dec 11, 2021 21:48:43 GMT -5
Post by pete130 on Dec 12, 2021 4:02:46 GMT -5
Well I can't get right squish with base sealing its either leak and have what its ment to or no leak thats if the sealed works and and have..7 still can't work out how u tarque a nut you can only get a open ender spaner on, I would say that's why im having trouble with it cant tarque so bet its to much on one and not enough on other, any ideas, im pulling.my hair out near had som many problems, with whats ment to be a simple build, the worse build motor ive seen or done and its full malossi its not funny any more
Post by ryan_ott on Dec 12, 2021 11:14:45 GMT -5
Are you using sealant on the gaskets? Search crows foot wrench for what will help you torque the nuts down.
Post by pete130 on Dec 12, 2021 21:21:55 GMT -5
Well sorted out problem with flage nuts torquing, had to buy this
Post by pete130 on Dec 12, 2021 21:22:31 GMT -5
Post by pete130 on Dec 12, 2021 21:24:58 GMT -5
Yes I used selent second time to seal, but there's the problem add more squish, but im winding if a bit more may be a good thing for reliability, I would be happy with .65mm instead of the .55mm ist asking. I've orded a spaner taque wrench so I can do right, I may be doing up to much and that's creating leak, thanks for your help
