Post by milly on Dec 17, 2021 12:19:17 GMT -5
messenger
Post by messenger on Dec 17, 2021 12:25:18 GMT -5
Maybe add a fresh seat cover to your parts list ![(angel)](//storage.proboards.com/2855264/images/kTxejnexfkJHgSpasjKf.gif)
Post by aeroxbud on Dec 17, 2021 16:00:47 GMT -5
Doesn't look too bad apart from the underneath.
Post by milly on Dec 17, 2021 16:47:52 GMT -5
Looks quite nice no painting needed on this and comes with lots of history and original bill of sale. Last chap owned it from 2006 and use to ride it up the A14 from Norwich and motorways to North Wales, Abersoch. Brave fella bad enough in my old wreck of a slow car with a trailer let alone a ET4.
Post by pinkscoot on Dec 18, 2021 9:06:58 GMT -5
Very nice, 20,884 miles it's just broken in. You'll get the rust on the bottom sorted and it will be as good as new.
Post by milly on Dec 18, 2021 11:58:25 GMT -5
Petrol in and running fine. ![](https://uploads.tapatalk-cdn.com/20211218/fc218ef0d1dae80537e095c7b3246227.jpg)
Post by milly on Dec 21, 2021 11:55:06 GMT -5
Filter, drive belt, rollers and tyre arrived today. Found a spare center stand and new pet cock in shed and inlet manifold to replace the cracked one. Engine run up and oil and filter changed.
Post by milly on Dec 23, 2021 7:53:29 GMT -5
Exhaust a bit knackered and the leader one I have don't fit on the back end of bracket. New tyre on problem with one seized bolt to lift air box out the way to remove last bolt for variator cover. Im in talks with a chap in Hillsea to pick up complete engine and exhaust next week at some point engine seized but ok for spares. ![](https://uploads.tapatalk-cdn.com/20211223/3916741bcd0d0dffc772c8d19f55e8c3.jpg) ![](https://uploads.tapatalk-cdn.com/20211223/9c462e36c75f69ea210551516338b3dd.jpg) ![](https://uploads.tapatalk-cdn.com/20211223/cc6fe55aa23e0bfebfeb5f3f2e920d4c.jpg)
Post by jloi on Dec 23, 2021 12:04:57 GMT -5
milly - that body and paint looks great
Post by milly on Dec 23, 2021 12:36:22 GMT -5
It is nice jloi thank you
Post by milly on Dec 24, 2021 9:25:07 GMT -5
Oh well no exhaust anywhere so cut the old and join to the spare one. Jobs a good'n Just fitted new battery. ![](https://uploads.tapatalk-cdn.com/20211224/2f51e7d49f4bd21a902403373a26cbae.jpg) ![](https://uploads.tapatalk-cdn.com/20211224/e3dd251ad48a0c02f9311f2c284247e1.jpg)
Post by milly on Dec 26, 2021 12:44:48 GMT -5
Done working on it this evening all bolts loose on transmission case damn airfilter bolts being a pain after drilling. ![](https://uploads.tapatalk-cdn.com/20211226/cfaf4faa7c00102d7f41e511ef974e75.jpg)
Post by milly on Dec 27, 2021 16:23:44 GMT -5
Went back to this, bit of brute force on airfilter moved out the way belt and rollers on. Now to unseize the kick starter.
Post by aeroxbud on Dec 27, 2021 16:45:08 GMT -5
That's the problem I used to have with the habana. Oil filler sticks up too high. And above it the air box and body stop you moving the CVT case any higher. Bloody nightmare. Lol
Post by milly on Dec 27, 2021 17:37:50 GMT -5
That's the problem I used to have with the habana. Oil filler sticks up too high. And above it the air box and body stop you moving the CVT case any higher. Bloody nightmare. Lol Indeed I remember a post you mentioned about removing the battery put me off looking at them wondering what other esteemed wonders they would throw up aeroxbud ☺️
