2004 Yamaha Zuma Sport Build
May 4, 2022 22:02:47 GMT -5
via mobile
190mech, repherence2, and 1 more like this
Post by girldad93 on May 4, 2022 22:02:47 GMT -5
First time scooter owner here, picked up a non-running 04 yamaha zuma 50cc 2-stroke that needed some work with about 8000 miles. Cleaned the carb, replaced the reeds/reed valve, replaced the spark plug, replaced the battery, and got it running, although it would die while coasting to idle on occasion. From there, adjusted the idle air screw and idle speed screw, and it has been running good ever since.
On to the build, I plan on setting up a mild sport build, low end acceleration is more important to me than high top speed, also hopefully trying to stick with the stock crank for now.
Ordered one of the "Sport" Kits from Scootertuning:
Polini 70cc Sport Cylinder
Polini Speed Exhaust
Polini Hi-Speed Variator Kit (variator with 6.9g rollers, green clutch springs, soft contra spring w/ evo slider)
Stage6 Main Jet Kit 80-102 6mm Kit
NGK BR9ES Spark Plug
I also picked up a pilot jet from a vino (think its a 46) just in case its needed, new pair of michelin boppers, front brake pads, new crank seals and other misc gaskets, a set of 6g rollers, a new oem air filter, and a polini belt.
So far, got the new tires put on, brake pads replaced, and made up a leak check tester to find that my intake manifold/reed valve assembly was leaking pretty bad, 5psi would leak down to 0 visibly in a few seconds. Couldnt get it to seal with the new gasket alone, but sealed fine once I added some grey rtv to both sides. Checked crank seals but they did not leak at all. After letting the rtv cure, the system held 5psi for an hour without decreasing at all. I found that oil would leak into the carb if the scooter sat for a bit, also was some leakage at the pump itself, just went ahead and removed the pump/lines/tank, and will be running premix. Also changed the gear oil.
The plan is to install the parts on the original cylinder, get issues worked out/work on tuning, then swap in the new cylinder and finish fine tuning.
I have been reading on here for quite a bit over the past few weeks and have learned a ton from other people's past experiences, however I do still have a few questions.
I have been trying to get the polini speed exhaust on, but it does not seem to want to fit with the supplied bracket. I dont recall seeing any builds on here with this same pipe. Is it common to have these not fit correctly? Looks like i will have to mount the pipe behind the bracket instead of in front (which attaches to welded on spacers with rubber bushings), and add 2 additional pieces of metal to lower the mounting points about 1.5" from where the original mounting points are, unless I am completely doing this wrong.
Spark plug supplied for the kit is a NGK BR9ES, should I use this or pick up a BR8ES? I guess the 9 just seems like a pretty cold plug for the setup ill be running but maybe not.
I have not ordered a clutch, will the oem 2-shoe clutch be alright to use for now with the polini green springs?
As far as installing the contra spring with the evo slider, how exactly are the slider pieces supposed to be assembled with the spring? Theres a metal perch that goes on one side of the spring, and then a plastic ring that tapers in size, not sure way and what side (clutch or pully) each one of these goes on. Haven't separated the original assembly yet, maybe this will make more sense once I do.
Any other recommendations for a first time build are welcome. Thanks.
