Post by milly on Apr 17, 2023 12:42:16 GMT -5
The seagulls were wrong aeroxbud and FrankenMech. It's a 2018 Peugeot Tweet 125cc for £50 and not a Kisbee 50cc. Good nick all round except one side panel replacement on the right and rear brake lever. Engine tried to turn over slightly so might be a snaped drive belt jamming the crankshaft as noticed oil in the sump and not new stuff which people tend to put in if run out. We will see in the week at some point what it is.
Post by FrankenMech on Apr 17, 2023 14:10:25 GMT -5
Excellent find for a 125 even if it was £50 above the 'right' price LOL Sorry, my brother in law and I are incorrigible scroungers always looking for the 'right' price. Moths fly out of our wallets when we open them. We both have sheds full of projects. Unfortunately as we have aged fewer completed projects exit the shed... We will only cut one corner off your 'scrounger' man-card for the price. You can earn it back if you make £200 profit on the scoot What size wheels does that scoot have?
Post by aeroxbud on Apr 17, 2023 14:42:37 GMT -5
That's well worth the price. 👍
Post by milly on Apr 17, 2023 15:19:55 GMT -5
Post by milly on Apr 18, 2023 12:55:13 GMT -5
So after checking the belt that's fine. Checked oil and there is none so just a case of cross reference of what the engine comes from and price up parts or second hand engine which will be the easiest route. Maybe the GY6 generic one's have a model with same engine mount and 16" wheels.
Post by rollingbender on Apr 18, 2023 13:10:29 GMT -5
Where do the mounts attach to the motor? Top or underneath?
Post by FrankenMech on Apr 18, 2023 13:30:39 GMT -5
No oil, none? Was it leaked out, drained, or just burned up?
That spark plug looks clean, maybe the piston/rings/cylinder is OK.
Have you looked at the flywheel/stator end?
Some strange things have happened to equipment, did some kid drop pebbles or sticks in the crankcase?
Post by milly on Apr 18, 2023 13:56:26 GMT -5
Where do the mounts attach to the motor? Top or underneath? Not looked yet, will check tomorrow
Post by milly on Apr 18, 2023 13:58:22 GMT -5
No oil, none? Was it leaked out, drained, or just burned up? That spark plug looks clean, maybe the piston/rings/cylinder is OK. Have you looked at the flywheel/stator end? Some strange things have happened to equipment, did some kid drop pebbles or sticks in the crankcase? Doesn't appear to have leaked any, stator end appears ok will look when have chance.
Post by geoffh on Apr 18, 2023 14:36:06 GMT -5
Just a cautionary note,I purchased the wrong 2hd engine for my kisbee,the manual (gone with scoot) listed quite a few variants.
Post by milly on Apr 19, 2023 4:52:10 GMT -5
Just a cautionary note,I purchased the wrong 2hd engine for my kisbee,the manual (gone with scoot) listed quite a few variants. Geoff Thanks for that Geoff, I just looked on Racing Planet for parts and they show loads of various models of the 125 twist over the years so god knows how many engine variations they have. I may put this to the back of the shed till more conversant with them. plus the Sym Symphony is meant to be the same with many iterations as well.
Post by milly on Apr 20, 2023 6:53:58 GMT -5
Well took some measurements between the head studs across etc and none measured the same as any I have come across on various websites. Start again later.
Post by milly on Apr 20, 2023 15:27:57 GMT -5
Post by aeroxbud on Apr 21, 2023 5:29:50 GMT -5
That's some serious damage to the piston.
Post by FrankenMech on Apr 21, 2023 11:40:53 GMT -5
Kind of what happens to pistons etc when there is no oil. New engine time or just scrap the Caddy Clyde as Clint Eastwood would say.
