Post by Zino on May 14, 2023 8:41:07 GMT -5
if you are having trouble starting it with carb cleaner your carb settings are not right. I ran stock air box The dellorto 19 with 40 pilot and 82 main purred like a kitten and I got my best top speeds . Going bigger on the pilot than a 40 hurt my throttle response and gave me sluggish take offs . Jets in the high 80s would give me lower speeds than low 80s My cylinder head temps on long 30-5 mile wide open runs would settle around 340-350 degrees .
My build was almost identical to yours I ran malossi 70 cc yasuni r and gears .
Do you have a rpm or temp gauge . Both would help with tuning .
Post by yanaha on May 14, 2023 17:20:35 GMT -5
Last week I tried a 40 pilot and it fixed my issue at take off but it never started by itseft like a 45. Maybe I should unscrew the mixture screw more. I’ll try the 40 again tomorrow and play with it more. I don’t have any other gauge than the stock speedometer.
Post by Zino on May 14, 2023 18:35:07 GMT -5
You can use a gps app on your phone so you can measure to the tenth of a mile for speed For baseline tuning I run the fattest main jet and work progressively leaner and take the jet that gives me the best top speed and responsiveness. If 2 jets feel the same I take the richest one.
Try this to see if you are in the right range of a pilot after the scooter is real warmed up
With it idling blip the throttle a few times 3 things will happen 1)the idle speed will hang out a higher speed then normal This is lean and you need to go richer by turning the air screw richer 2)The idle speed will drop back to normal almost immediately This is perfect for a daily rider 3)Idle speed will drop below normal speed and then clean up ,Racers like this because after they come off of wide open throttle They get a blast of extra rich fuel for cooling purpose to keep from seizing
For a daily rider go for 2 first 3 second Racers take number 3
You want a pilot jet that you can control between 1 to 3 turns out with the mixture screws
Do the wide open throttle test . On race day we used this to make sure we had right jetting for the day after your scoot is well warmed up . Try running wide open on a flat surface a few times Back off the throttle by 1/4 turn. This will make you a notch richer temporarily . 3 things will happen 1)Rpms will rise or speed increases .This means you are a notch lean on the main jet and need to go up a jet. 2)Rpms/speed will drop slowly this is close to spot on 3)Rpms speed drops fast this is a notch rich try a leaner main.
For the needle I just go for the most responsive on and off throttle position if 2 feel close to the same I go with the richer needle setting.
Post by repherence2 on May 15, 2023 22:38:20 GMT -5
are you running the Over range kit or are you running the Multivar?
Post by repherence2 on May 15, 2023 22:42:17 GMT -5
...if only they knew...
temp for carb tuning.
tach for CVT tuning.
the best $100 in tuning tools you could ever have. longevity, reliability, and maintenance indicator.
Post by yanaha on May 16, 2023 11:21:18 GMT -5
Thanks Zino for your help. I just give up and sent it to a mechanic to check it. I’ll let you know when its done.
Post by yanaha on Jul 7, 2023 20:34:49 GMT -5
So welcome back, the mechanic didn’t even touch it in 2 weeks so I brought it back to home. I played with pilot and checked the float, was in specs (16mm) so I put back the stock carb and wired a temp and tach gauge. With the stock carb with a 92 main jet the temp stayed at 240-245F at wot with a top speed of 76 km/h. Is it safe to downsize the main even if the stock is a 80-82?
Post by Zino on Jul 8, 2023 9:09:31 GMT -5
You have room to drop the main
how far are you running wide open a block or a couple miles at a time ? If more than a mile you are running on the way rich side . for refernce on my zuma i always let it warm up to 140 degrees before take off my first stop sign is just under 2 miles away. My temp gauges gets breaks 300 degrees by the fits stop sign . The next one is 4 miles away i will then drift up on that run and hold in the 340 range .
since you have a tach use that to help find your main jet do high speed wide open runs on the same 1/2 mile stretch progressively drop jets track peak rpms as you go down your peak rpms will rise and then level off on a couple of jets so for example 92 jet 8700 rpms 90 jet 8900 rpms 88 jet 9100 rpms 86 jet 9200 rpms 84 jet 92000 rpms
for a daily rider i would look at 86 over the 84 its richer now the double check you would use is after this is make sure your temp levels off below 350 with that jet on long wide open runs
Post by yanaha on Jul 8, 2023 14:17:53 GMT -5
I did about 16km of wot in two shot of 8km. I put a 90 this morning and redid the same test. The temp stayed between 250-257F and the rpm raised from 9200 to 9400 and dropped to 9300 after few km. So judging by what you say I will put a 88 and go for a ride again. I’ll order another set of main jets because my lowest is a 88.
Post by Zino on Jul 8, 2023 16:46:59 GMT -5
8km is a good healthy distance for testing wide open blasts The biggest key with the temp gauge is you want to see it just level off and hold a temp for long periods . Since the fuel mixture provides about 80% of the cooling on these air cooled beasts .
what jets are you using mikuni or dellorto ?
with genuine mikuni 85 -88 was a sweet spot for jetting with the stock carb for me with stock airbox.
Post by yanaha on Jul 8, 2023 17:31:11 GMT -5
I have Stage6 jets kit and I ordered a Polini 10 pieces kit (80 to 98). Maybe that brand have other spec than dellorto or Mikuni? I came from my test with the 88 from Stage6. Temp was climbing 273F after about 10km and stayed there. Rpm started at 9600 than gradually dropped to 9300-9400.
Post by Zino on Jul 8, 2023 21:16:35 GMT -5
Sounds like you are closing in on the right jet My bet a 86 or 84 will be the right one
When you switch over to polini start with 88 just to make sure it is in the same range as the stage 6 It should be but it pays to be careful as you are getting closer to the right range
Polini and stage 6 make dellorto jets that fit the Yamaha carb
Post by Zino on Jul 9, 2023 12:02:38 GMT -5
hellish has tuned quite a few scoots he is using the same method to dial in his kymco 49ccscoot.proboards.com/thread/29836/zx50-rescue-alive?page=3your getting close to right on with your jetting on the main the tempature jumps with a bigger gap from the last jet as you get real the other big clue is your rpms are starting to find a upper range
Post by yanaha on Jul 12, 2023 21:01:42 GMT -5
I tried the 86 from Polini, it got to the same temp but it was pretty windy. My top speed was about 82 km/h with 5.75g in the Multivar and a yellow contraspring from Malossi. I got 5mm left on the variator. I will try heavier rollers maybe some 6g or heavier tomorrow if the weather allow me to.
Post by Zino on Jul 12, 2023 21:56:47 GMT -5
too avoid chasing 2 demons your close on the carb stick with the 86 if you are moving onto dialing in the cvt
I noticed you have the oversize variator up front ,If that is 99 mm across ,the stock belt will get travel on the 97 mm variator to under 2mm . Does the variator hit under 1mm left on the inner edge of the variator ? Do you have shims to change the length of the drive boss to adjust the travel on the variator ?
