Post by erikvind on Jun 21, 2024 9:16:54 GMT -5
I am having a problem with my Yamaha Jog R When I start the scooter i drives very well the first 300 meter until the echokes turns off. then it slowes down until it stopes, and idles. after 5 sec I can give it some throttle and i goes again. then after 2-3 minutes on throttle it does the same thing again. getting slower, and slower untill it stands still and idles.
if i hit the sweet spot on a longer drive. it can continue to drive without problems. but if I give i full throttle it slowes down till stand still and idles.
Carb has been cleaned many times, and there is a new fuel filter on it.
if i suck on the vacumhose, alot of fuel comes out of the fuelhose.
the fuelcap vent is clean
Post by Zino on Jun 21, 2024 11:03:23 GMT -5
Is this scooter new to you ? Is this a new problem? What else have you done recently to the scoot ?
First law of scooter tuning is to make one change at a time so you can retrace your steps .
Are you using a stock Airbox? It works best open filters are very hard to tune . What main jet is in right now ,Do you have others ?
On the Air mixture screw how many turns out are you With stock set up 1 1/2 -2 turns out is the starting point
Can you post a video of the problem ?
Post by erikvind on Jun 21, 2024 11:56:26 GMT -5
it is somewhat new to me. have driven it too and from work for the last 3 weeks. it has standart parts on. except the exhaust ist is a polini with the govern in it, because it has too in mt country. it has stock airbox with a new filter in it. if i recall the main jet is 62 original for the gurtner carb it should be 1 1/2 - 2 turns out on the mixture screw
when i got the scooter the needle was in the highest position, i put it back to the mitle one, and the sparkplug looks like it has good mixture
Post by Zino on Jun 21, 2024 13:53:49 GMT -5
Post by Zino on Jun 21, 2024 13:57:34 GMT -5
Post by erikvind on Jun 28, 2024 5:00:23 GMT -5
it helped remowing the restriction in the exhaust. but now it is not roadlegal anymore in my country
Post by Zino on Jun 28, 2024 7:32:57 GMT -5
I won’t tell anyone Just enjoy it
