Post by abansb on May 3, 2012 0:59:11 GMT -5
no it is not a sealed carb
I got the top speed to 33 mph I am not sure what the main jet don't know how to tell what the jet is I am using the stock airbox
Post by Deleted on May 3, 2012 1:21:34 GMT -5
is this smooth power up to 33mph or is it skiping and bucking? If you have not put in at least an 85 main jet with a 50mm bore its lean as hell. a lean motor will bog and buck like crazy. maybe your throttle is not opening all the way?
Post by abansb on May 3, 2012 6:14:47 GMT -5
yes this is smooth there is no skipping or bucking I have not put any jets at all
Post by abansb on May 3, 2012 11:28:02 GMT -5
here is another thing the new drive boss was longer than the old one I put the old one back one not for sure if it will make a difference it was like 1/4 of on inch longer than the old one
Post by abansb on May 3, 2012 12:00:45 GMT -5
I just took a short ride top speed at 35 mph on the speedo it has take off power and don't change speed going up hills stays right at 35 mph I just don't understand what is wrong
Post by abansb on May 4, 2012 4:21:34 GMT -5
I just got my new rings in today going to put them in here in a few days
Post by Deleted on May 4, 2012 12:36:24 GMT -5
i thought you just did that?
Post by abansb on May 4, 2012 23:50:16 GMT -5
no I haven't replaced the rings yet could that be the problem ?
Post by Deleted on May 5, 2012 0:32:32 GMT -5
I strongly recommend a compression gauge. it will eliminate all this guesswork.
Post by abansb on May 5, 2012 0:41:49 GMT -5
ok I will get one I thought maybe it could have been something else I really want to get this scoot running right I am sure I need to up the jets also
Thanks for the help 1FASTQMB
Post by peteyparado on May 6, 2012 4:07:21 GMT -5
how much miles have you gotten on the bbk? it will get faster when its broken in.. but do the compression test it will answer a lot of your questions.. i know for my 50mm bbk it went only about 40mph before break in.. after break in it went 50mph...
Post by abansb on May 6, 2012 22:12:43 GMT -5
It doesn't have many miles on the bbk
Post by abansb on May 10, 2012 18:34:08 GMT -5
Ok I got the rings in last Friday just replaced them today the smoking has stopped seems that the power is back haven't really took her to far to check the speed will hopefully get to soon
I can be setting still on the seat and hit the throttle and she will spin the tire
I am just wondering if I get a performance clutch and variator if it will also help on speed
Post by abansb on May 10, 2012 22:50:23 GMT -5
I took her out for a little ride I got 45mph on flat so everything is back to normal just have to break her in now
Post by Deleted on May 10, 2012 22:53:14 GMT -5
sounds like it had low compression.
