Post by abansb on May 11, 2012 0:04:20 GMT -5
yea I wasn't for sure if it was the rings or not
when I took her out I got stuck my kick start broke and battery was dead I had to get my brother to come give me a jump I don't know how it happened but it broke the teeth off the thing that the kick start pushes up against the flywheel I heard a big pop earlier when I started it. I had another one I put it on and it broke the teeth off it I am guessing it is something else inside the CVT cover I replace the cover and it is working fine now
Post by peteyparado on May 11, 2012 0:37:35 GMT -5
what kind rings you put on? or where did you get it from?
Post by abansb on May 11, 2012 7:08:40 GMT -5
I got them off ebay the same guy I got the bigbore from I sent him a message and he sent me a new set of rings
Post by abansb on May 11, 2012 9:34:34 GMT -5
I went out this morning to go to the store hit the kick start and pop it cracked my CVT cover right down the middle did't break the teeth off so I repaired the other cover I had but it is still acting funny I am charging my batter to keep from using the kick start till I figure out what is going on
Post by Deleted on May 11, 2012 9:41:40 GMT -5
I only use it for emergencies.... and it saved me from walking what would have been a looooong walk once so yeah gotta have a working kick start IMO.
Post by abansb on May 11, 2012 9:57:31 GMT -5
the one I repaired works but I am afraid it is going to break it I replaced everything in the CVT cover and the flywheel it seems like it isn't catching just right
Post by abansb on May 11, 2012 23:36:40 GMT -5
what is happening is my engine is kicking back in mid kick that is what is breaking the teeth and cracking the cases I can't figure out why it is doing it
Post by Deleted on May 12, 2012 22:38:18 GMT -5
sounds like real high compression. I am assuming you are not using the electric start because it will not turn the motor right?
Post by abansb on May 13, 2012 1:10:07 GMT -5
no I charged the battery it wont start it
Post by abansb on May 13, 2012 10:25:19 GMT -5
if I get another base gasket will this help if so can you point me to the one to get that might work my piston is flush with the top of the head
Post by peteyparado on May 14, 2012 2:36:11 GMT -5
partforscooters.com has them for $10.99
Post by abansb on May 14, 2012 6:36:34 GMT -5
this should bring the compression down ?
Post by Deleted on May 14, 2012 7:05:47 GMT -5
yes i suggest a better starter too there is a thread here about good starters
Post by Deleted on May 14, 2012 7:06:31 GMT -5
that good starter alone might work
Post by abansb on May 14, 2012 7:30:51 GMT -5
ok thanks will check it out
