Post by abansb on May 16, 2012 11:05:54 GMT -5
I ordered 2 base gaskets going to try one at a time to get the compression down they will be here tomorrow will put them on this weekend
Post by abansb on May 24, 2012 10:07:47 GMT -5
ok I got both gaskets on and now I can start with the electric start I used 2 thin gaskets
I am wanting to get the clutch worked on now I was wondering should I get a performance clutch or just get the springs replaced
Post by peteyparado on May 24, 2012 14:46:01 GMT -5
how does the scoot run now?
Post by abansb on May 24, 2012 23:57:34 GMT -5
It runs good got a lot of power my top speed is around 45+ mph hopefully it will get more after break in I ordered a set of clutch springs and contra springs a set of 2k and set of 1.5k going to put them on 2 different clutches to test
Post by peteyparado on May 25, 2012 2:15:49 GMT -5
i went with the 1k torque spring an i lost about 5mph on the top.i had to compensate with heavier rollers from 6g to 3-8.5g an 3-7g an my speed back plus some.. did u get a lighter bell with those clutches?
Post by abansb on May 25, 2012 6:53:24 GMT -5
I didn't order no clutches they are stock clutches just got springs
Post by peteyparado on May 25, 2012 14:00:03 GMT -5
oh ok but u should get a lighter bell.. an have fun testing an tuning
Post by abansb on May 25, 2012 18:16:46 GMT -5
ok I will look for a lighter bell thanks
Post by abansb on May 27, 2012 10:20:07 GMT -5
Post by abansb on May 31, 2012 11:15:54 GMT -5
what would be a good combo to try
Red Torque Spring 2000rpm Yellow Clutch Springs 1500rpm
Yellow Torque Spring 1500rpm Red Clutch Springs 2000rpm
Yellow Torque Springs 1500rpm Yellow Clutch Springs 1500rpm
Red Torque Spring 2000rpm Red Clutch Springs 2000rpm
I also have a set of blue 1000 RMP Clutch SPRING SET
Just wondering which combo might get me better performance ?
Thanks
Post by revweasel on May 31, 2012 15:43:14 GMT -5
did you by chance do a comp test before and after the gaskets? just curious as i might try it since my elec start is laboured. if i crack the throttle at all it has a hard time getting passed tdc. but it still does and it starts easy so it isnt a big issue. but, isnt the higher comp free power really?
Post by abansb on May 31, 2012 23:56:23 GMT -5
I did not do a comp test had no way of testing it
Post by peteyparado on Jun 1, 2012 0:01:27 GMT -5
i use 1k torque spring an 1kclutch springs... i tried stiffer springs but its harder to drive at slow speed below 10mph.. an u lose some top end mph.. u might have to compensate with heavier rollers or slider weights. to get speed back.
Post by abansb on Jun 1, 2012 0:09:31 GMT -5
I also have high performance variator with a set of 5g 7g and 9g rollers wanting to mix and match to get better performance out of them also
Post by peteyparado on Jun 1, 2012 3:13:07 GMT -5
sounds good i mixed 8.5g an 6g... you'll find a good match for your scoot just be patient takes a while finding a good match. have fun tuning...........
