Post by 90GTVert on Aug 7, 2012 20:49:41 GMT -5
Definitely.
Post by thestratomaster on Aug 7, 2012 20:58:28 GMT -5
Sweet, so I can pretty safely assume that parts for minarelli's should fit mine? Once it gets fixed it's not staying stock for long
Post by jmkjr72 on Aug 7, 2012 21:11:14 GMT -5
you have to watch your trans parts
becuase it has an odd trans you have a short case gear set up yet the actaul case is a long case so you need a realy long belt
you also will not be able to find an over range that will work with that set up becuase no one makes a proper belt
but the bores are the same and it runs the small shaft varatior and small taper fly wheel
Post by thestratomaster on Aug 7, 2012 21:53:24 GMT -5
What makes you say it has short case gears?
Post by jmkjr72 on Aug 7, 2012 21:55:26 GMT -5
i have one of those engines sitting on my shelf that im building to a bigblock stroker
Post by thestratomaster on Aug 8, 2012 14:32:10 GMT -5
i have one of those engines sitting on my shelf that im building to a bigblock stroker Gotcha hah
Post by thestratomaster on Aug 8, 2012 22:31:37 GMT -5
Started cleaning the case up a bit today so I can get a good look at things. There was really a lot of grime on this thing. Took the exhaust off to see this. Nice. Where else should I be looking for big carbon build up? and matching exhaust port My lovely little mess
Post by 90GTVert on Aug 9, 2012 4:32:32 GMT -5
That's a lot of build up. Seeing that much, I'd take the head off too and see how it looks in there. Blow through the exhaust and see if air comes out so you know if it's clogged inside anywhere too.
Post by 2strokd on Aug 9, 2012 8:36:46 GMT -5
:scared: :help: . Looks like someone used glue for oil in there Prime example of a good reason to use good oil :cheers: Let the black dust FLY :chinese:
Post by thestratomaster on Aug 9, 2012 16:28:58 GMT -5
That's a lot of build up. Seeing that much, I'd take the head off too and see how it looks in there. Blow through the exhaust and see if air comes out so you know if it's clogged inside anywhere too. Through the actual exhaust or the exhaust port?
Post by thestratomaster on Aug 9, 2012 16:32:13 GMT -5
. Looks like someone used glue for oil in there Prime example of a good reason to use good oil Let the black dust FLY Yeah, would the 4 stroke oil have done this? Or just running really lean on oil in general. What's the best way to knock the carbon free? I've not worked on 2 strokes or small displacement motors before, but should I have gaskets waiting before I put the motor back together? Idk if head gaskets are much of an issue on a 50cc 2 stroke. On a side note, on first glance, I did not see an oil drain plug or oil reservoir or anything. Where should I be looking to drain any oil in there out?
inuyasha
Retired Master Chief USN
Post by inuyasha on Aug 9, 2012 16:47:11 GMT -5
Hi The oil reservoir on a 2t should be under the seat of the scoot, from there its auto mixed in with the fuel and burned during combustion. Take care and ride safely Yours Hank
Post by thestratomaster on Aug 9, 2012 16:48:50 GMT -5
Hi The oil reservoir on a 2t should be under the seat of the scoot, from there its auto mixed in with the fuel and burned during combustion. Take care and ride safely Yours Hank I'm not sure mine has that hah. The pump should be by the flywheel right? If it were to have one
Post by jmkjr72 on Aug 9, 2012 17:03:36 GMT -5
it will be under the fan and fly wheel very small
i see the oil line comeing out by the stator area in your pics
Post by thestratomaster on Aug 9, 2012 18:51:48 GMT -5
it will be under the fan and fly wheel very small i see the oil line comeing out by the stator area in your pics The one thats hanging out by the spark plug? That was attatched to the carb? I'm assuming that was incorrect?
