Triton
May 11, 2011 22:20:37 GMT -5
Post by 90GTVert on May 11, 2011 22:20:37 GMT -5
If they won't hold, you could see if the next size up either sae or metric could be used and the block tapped accordingly. Not sure if there's really enough room though if the intake/reed bolt holes needed to be enlarged.
Triton
May 11, 2011 22:38:27 GMT -5
Post by Reign on May 11, 2011 22:38:27 GMT -5
If they won't hold, you could see if the next size up either sae or metric could be used and the block tapped accordingly. Not sure if there's really enough room though if the intake/reed bolt holes needed to be enlarged. I'll have to see what I can do. Honestly, at this point, I just want to get it running it's best, and get rid of the thing ASAP. If something happens to it after that, oh well. I'll be in Florida and the next guy can deal with it :rofl:
Triton
May 19, 2011 20:46:17 GMT -5
Post by Reign on May 19, 2011 20:46:17 GMT -5
106 main jet (maybe 108, can't remember) and a 32.5 idle jet = front wheel came off the ground when pulling out of my driveway earlier!
Triton
May 19, 2011 21:05:02 GMT -5
Post by 90GTVert on May 19, 2011 21:05:02 GMT -5
:thumb: Nice, but can you do a backwards wheelie?
Triton
May 19, 2011 21:46:04 GMT -5
Post by 2strokd on May 19, 2011 21:46:04 GMT -5
Thats nice man . Vids man vids :popcorn: Hhhmmm backwards wheelie . Can i sit backwards and do it?
Triton
May 19, 2011 21:50:55 GMT -5
Post by 90GTVert on May 19, 2011 21:50:55 GMT -5
Sit however you want. If you can get the scoot to go backwards though you just invented the moonwalk wheelie. lol
Triton
May 19, 2011 21:52:50 GMT -5
Post by 2strokd on May 19, 2011 21:52:50 GMT -5
k
Triton
May 19, 2011 22:16:39 GMT -5
Post by Reign on May 19, 2011 22:16:39 GMT -5
Uh oh Brent. I think you just provoked a new scooter for next years TnG. We're gonna see Robert there with a backwards scooter doing wheelies with his arms behind his back.
Triton
May 19, 2011 22:22:57 GMT -5
Post by 90GTVert on May 19, 2011 22:22:57 GMT -5
Na. I think he's just tired of me being a dummy. lol You never know though.
Triton
May 19, 2011 23:04:35 GMT -5
Post by 2strokd on May 19, 2011 23:04:35 GMT -5
No, ive been thinking of how that can be done :stumped:
Triton
Jun 1, 2011 16:59:41 GMT -5
Post by Reign on Jun 1, 2011 16:59:41 GMT -5
I do believe this thing is trying to drive me insane. I threw on my "paper" filter, thinking it might tell me if I'm lean or rich. Found out I'm lean with the foam filter. I tune it a bit with the paper filter (which is at least TWICE as loud as the foam filter) and it's running B+ in the higher RPM's. Off the line, it's a slug. So I get home and throw a bigger idle jet in it, seeing I was already at the lowest I have, I figure it must be lean. I go to throw the carb bowl back on after the jet swap, and one of the screws stripped the threads on the carb body! I'm tempted to take the carb off, and re-thread the thing with american threads, just so I can actually get screws from the hardware store. Freaking Chinese threads that are such a fine metric size that they strip that easily, and are impossible to find even in metric countries! What do you guys think I should do?
Triton
Jun 1, 2011 18:08:08 GMT -5
Post by drawkward on Jun 1, 2011 18:08:08 GMT -5
Does it have space to drill it out and put a nut on the other side; like a through bolt?
If not; tap it up a size. Easy. Just sucks that you gotta have that one special screw different from the rest - unless you tap all four.
Triton
Jun 1, 2011 19:29:24 GMT -5
Post by Reign on Jun 1, 2011 19:29:24 GMT -5
Does it have space to drill it out and put a nut on the other side; like a through bolt? If not; tap it up a size. Easy. Just sucks that you gotta have that one special screw different from the rest - unless you tap all four. Nah, it's the place where the last dude put a wood screw in it And directly above it is the oil injection port, so there's no way to put a nut there. Maybe I'll just throw the wood screw back in there temporarily, until I feel like taking it off to retap it. I already am running with 1 screw different than the others. I ended up using one of the carb screws from RD in the other side. The only one that fit was the reeeeeally long one, so it takes forever to screw it all the way in after a jet swap :laugh:
Triton
Jun 2, 2011 10:07:11 GMT -5
Post by drawkward on Jun 2, 2011 10:07:11 GMT -5
Aw man I hate those looong carb screws. Makes jetting such a PIA. I have been using the stock phillips and a power drill to do my jetting sessions.
All this trouble, man - seems like a brand new carb would be worth it by now. Everything else on that bike is pretty much flawless, right?
Triton
Jun 2, 2011 16:27:51 GMT -5
Post by Reign on Jun 2, 2011 16:27:51 GMT -5
Aw man I hate those looong carb screws. Makes jetting such a PIA. I have been using the stock phillips and a power drill to do my jetting sessions. All this trouble, man - seems like a brand new carb would be worth it by now. Everything else on that bike is pretty much flawless, right? Yea, I was hitting low 50's with the stock carb and an upjet. Now I'm lucky to hit 45. Though that other filter I threw on yesterday made a big difference. I think I may actually be able to get it tuned now that I fit that on. Another question. I've got a leakdown tester I made last year. My question is, can I plug the exhaust up at the end, instead of removing it and plugging the port? I don't have anymore exhaust gaskets, and I'd hate to break that perfect seal I have.
