Triton
Jun 2, 2011 16:39:48 GMT -5
Post by 90GTVert on Jun 2, 2011 16:39:48 GMT -5
Yes, you can plug the exhaust pipe.
Triton
Jun 4, 2011 0:15:53 GMT -5
Post by Reign on Jun 4, 2011 0:15:53 GMT -5
There we go! Finally a day where my tune is almost right on! It's been a constant mess of weather lately. One day it'll be 90, the next 50, next 75 etc. Today I got to see just how nice this thing runs when it's 75 and slightly humid out. First off, I wasn't even really "in tune" for the majority of my ride to the store. Found that out when I was a few blocks from my house and I messed with the air screw Hitting it WOT down a main street, I saw my bicycle speedo hit 52 MPH, and then start counting backwards ;D I've got the Shwinn speedo, so it does that. I'd say I was probably doing 55ish at WOT! Oh, and the front wheel came off the ground again when I left my driveway :wheelie:
Triton
Jun 5, 2011 10:21:55 GMT -5
Post by drawkward on Jun 5, 2011 10:21:55 GMT -5
Pics or it didn't happen.
Glad to hear you got a good ride out of her!
Triton
Jul 3, 2011 20:53:48 GMT -5
Post by Reign on Jul 3, 2011 20:53:48 GMT -5
It's been a while since I've posted! Just wanted to let you guys know that I'm finally starting to get the Triton dialed in where it should be. It's amazing how cumbersome the job of finding the right jet combination is I was running a 35 idle jet for the last few weeks, with lots of bog after the engine warmed up. So today after it got cool out, I threw in a 40 idle jet. I figured if the bog got worse, I would reverse and go down instead of up. Well, I think it might need more like a 42.5 or 45, but it's close! Ever since I put the new carb on, it never mattered whether I moved the air screw in or out. There was never any audible change in RPM either way, but it seemed to help the performance, at least. That changed with the 40 jet. I finally got some audible feedback. Not only that, but after I tuned it up a bit, it took off from a stop sign with little to no bog. It felt like all of those videos I see where people hit the gas and there's a teeny tiny bit of lag and then it's full RPM. Right now the air screw is almost all the way out of it's threads. If I unscrew it anymore it'll just fall out I remember Brent saying something about out is rich on this carb. The RPM's shot up when I turned it out, so that seemed odd to me. Unless it was just so lean that richening it made it better. Either way, I plan on testing a 45 tomorrow and seeing where that lands me. If it's worse, I'll shoot for the 37.5 ;D I haven't touched my main jet in over a month, and iirc I'm running a 92. It got a lot better on the top end when I went from the 98 to the 92, but I'm still only hitting about 45 top speed, downhill. I might have to go to an 88. Ok, I feel like I'm rambling now. I wish you all the best of luck on your projects, and that you all have a fun summer of scooting! Now that it seems summer has finally paid Wisconsin a visit :clap:
mccanic
Triton
Jul 4, 2011 0:32:21 GMT -5
Post by mccanic on Jul 4, 2011 0:32:21 GMT -5
right summers finally here!
Triton
Nov 1, 2011 11:50:00 GMT -5
Post by Reign on Nov 1, 2011 11:50:00 GMT -5
Anybody have any ideas where I can get/what I can do for a head gasket on my Polini Sport kit? I really don't want to have to spend $20+ on another gasket kit that includes the exhaust and base gaskets. The one it comes with is a o-ring style gasket. Would it be possible to use the other type? Or if not, do you know of anywhere that sells just the o-ring gaskets on their own?
Triton
Nov 1, 2011 17:11:03 GMT -5
Post by lshigham on Nov 1, 2011 17:11:03 GMT -5
If you measure the o ring, you might be able to find one from an o ring supplier?
Triton
Nov 1, 2011 17:32:47 GMT -5
Post by Reign on Nov 1, 2011 17:32:47 GMT -5
If you measure the o ring, you might be able to find one from an o ring supplier? Aren't they made of something special to hold up to the heat?
Triton
Nov 1, 2011 18:04:55 GMT -5
Post by 90GTVert on Nov 1, 2011 18:04:55 GMT -5
Triton
Nov 2, 2011 8:36:31 GMT -5
Post by 2strokd on Nov 2, 2011 8:36:31 GMT -5
If all your running is the o-ring then obviously squish settings arent a problem.. Just run some RTV orange and be done with it. No gasket at all. I do it all the time for tighter squish settings.
Triton
Nov 2, 2011 8:38:03 GMT -5
Post by 2strokd on Nov 2, 2011 8:38:03 GMT -5
The RTV black works well too! Ive found all the grey "ridged" stuff to be too ridged and wont flex with the head and ends up leaking.
Triton
Nov 2, 2011 11:06:52 GMT -5
Post by Reign on Nov 2, 2011 11:06:52 GMT -5
The RTV black works well too! Ive found all the grey "ridged" stuff to be too ridged and wont flex with the head and ends up leaking. I went and picked up a small tube of RTV black. I think I'm gonna reuse my o-ring, smeared with some of that. I'll use it to put my case back together too. Thanks Robert :cheers:
Triton
Dec 4, 2011 10:27:45 GMT -5
Post by Reign on Dec 4, 2011 10:27:45 GMT -5
Been too busy working on other things lately, that the Triton motor has been sitting in the basement this whole time. Finally got a bit of time to work on it yesterday evening, and got all the ports matched. I did some port matching before, without splitting the case apart, and now I see that it was a terrible job. Now it's nearly perfect. Next I plan to print out a degree wheel and see where I'm at with my ports.
Triton
Jan 1, 2012 18:29:05 GMT -5
Post by Reign on Jan 1, 2012 18:29:05 GMT -5
Finally got around to working on the Triton again! I made up a degree wheel and such, took some measurements. Yesterday I posted my port map here: 49ccscoot.proboards.com/index.cgi?action=display&board=2perform&thread=176&page=2#45992Here's my info I've gathered so far. 0° TDC 94° Exhaust open 124° Boost/Transfer open 180° BDC All ports completely open (exhaust is only about 90% open) 236° Boost/Transfer closed 266° Exhaust closed 360° TDC 172° Exhaust duration 112° Boost/Transfer duration Now I really don't know what any of these numbers mean in the long run, or what I'm looking for. Hopefully one of you guys can tell me what to look for. Here's some pictures of my setup: Exhaust port just opening
Triton
Jan 1, 2012 19:15:23 GMT -5
Post by 190mech on Jan 1, 2012 19:15:23 GMT -5
Graham Bell's book goes through this well.If this is a race motor you'll want around 195+ total Ex duration and 130-132 Tr durations.Ex port should be 65% of bore diameter(chord wise). Brent has all this very well documented(as usual) elsewhere..
