Post by ryan on Oct 6, 2013 10:14:22 GMT -5
or g-force
Post by scoottrash1990 on Oct 6, 2013 13:57:10 GMT -5
thanks.....does anyone know if the aerox 100 pipes will fit me scoot?
Post by ryan on Oct 6, 2013 14:01:55 GMT -5
they will so will axis 100 jog 100 bws100 and grand axis 100
Post by scoottrash1990 on Oct 6, 2013 15:43:48 GMT -5
thanks ryan....i cant seem to find the clutch bell you told me to look at...
Post by ryan on Oct 6, 2013 16:38:31 GMT -5
try polini speed bell or just 105mm they are real critical wording site
Post by scoottrash1990 on Oct 8, 2013 18:39:42 GMT -5
i took the scoot out for its first ride today......it runs good on the low and top end....mid range not so good...trying to cruse at 35mph and it stutters a good bit.....if i give it more gas it runs fine.....what adjustments should i make to get it to run smoother....thanks
Post by moofus02 on Oct 8, 2013 19:02:03 GMT -5
I'd try adjusting the needle. Drop the clip one notch to richen it to see if it helps if it gets worse go the other way
Post by kevin55950 on Oct 8, 2013 19:05:53 GMT -5
What needle number do you have ? Look for the chart and find the part of your throttle which cause problems. They came with various different needles. W5 needles are best for the racing-oriented, higher-revving applications, but W7 are better for less tuned/lower revving scooters.
Post by scoottrash1990 on Nov 12, 2013 20:08:33 GMT -5
thanks everyone for the great info.....at the moment the scooter is covered up in the garage and will be there for a little while.....i decided to wait on tuning till i get the right parts to match the 103 motor.....and its now snowing here so all the bikes are tucked in for the winter.....i will be ordering the rest of the parts little by little over the next few months.....when the weather brakes i will have her back out and get her all tuned up....im sure i will have more questions when that time comes......
Post by 2strokd on Nov 15, 2013 9:43:56 GMT -5
I agree with Kevin. I always end up with a W6,or 7 when tuning street scoots. I believe once you get up into the higher numbers, say W16,17 the taper is about the same as the 6,or 7 but the overall length of the needle is shorter.?
Post by scoottrash1990 on Nov 27, 2013 17:41:29 GMT -5
i just got a chance to pull the carb and look at the needle...it says w16 on the needle....is this good for a street scoot?
Post by scoottrash1990 on Nov 27, 2013 19:21:01 GMT -5
i just checked my squish clearance and i got 2.49mm clearance... is this to much? what should i be shooting for?
Post by 90GTVert on Nov 27, 2013 19:39:18 GMT -5
Something like 1mm or just under is good, but if compression is high that way it can go wider. Ideally you'd run the tighter squish and modify the combustion chamber volume to get compression where you want it.
Post by raelhi on Nov 27, 2013 20:03:01 GMT -5
are there 100cc horiz min engines still available for sale?
Post by scoottrash1990 on Nov 27, 2013 20:07:40 GMT -5
so i should be shooting for around 1mm of squish? how do you modify the combustion chamber volume? what kind of compression should i be looking for? thanks Brent.
